Cat Loader Bucket Repair
  • Cat Loader Bucket Repair
    Hello. I am new to the forum but I have a few questions. I need to repair the bucket on my Cat 955K. There are rust holes in the corners of the bucket. This is a non contact area. I was told that I should use abrasive resistant steel.
    My first question is, what thickness of steel should I use? This is a non contact area on the bucket.
    Second question is, can I heat and bend one piece of steel to the contour of the bucket or should I cut 1"-2" pieces and individually weld them on to it?
    I also read that using a stick welder with 7018 is the best process.
    Here are a few pictures of the bucket.
ID:	668524Click image for larger version
ID:	668525Click image for larger version
ID:	668526Click image for larger version
    [ATTACH]38090[/ATTACH][ATTACH]38091[/ATTACH][ATTACH]38092[/ATTACH][ATTACH]38093[/ATTACH]
    Being a non contact area of the bucket you can use regular carbon steel and bend it to fit. The raised beads you see on the outsides of the bucket are hardfacing material. There are several brands of hardface material available but I always liked Stoody "31", or "35" for building up wear and impact resistant surfaces. You could cut out the rusted material, seam in new plate stock formed to fit, weld it in using 7018, and then build up the outer surface with hardfacing and be good to go. I've actually performed this same type repair numerous times seemingly an eon ago.....
    The 955, and 977 were a good series of tractor in days gone by. Kind of expensive to maintain these days as they age no?
    Thanks for reading/listening.
      I haven't had much trouble with mine. I bought it two years ago. It had a fairly new under carriage. It runs fine. The only issue is the bucket rusted out. I just use to to play around on my property. I only use it a few hours a week.
        Sounds like a good candidate for re~facing Anvils no?
        sigpicViceGrip
          Stoody "35" is geared toward impact resistance. It does have fair ductility where "31" is more of a wear resistant layer. Neither are very good for depth without a base to cover. I'd probably try a good 6010 layer capped with "35" in the application but am really guessing as I never had to grind anything to form when hardfacing. Certainly worth a try however.
            Used to love working on all the pivot point to the loader arms when much younger, (yeah, right) as they really were a high wear tractor as are any loader type tractor is. Both the 955, and larger 977 were a very good balance of weight to power to capacity and maintained a strong loyalty base before excavators really eliminated the market. The later series of those tractors started to use bushings in the pivot points and getting some of those SOB's out of their respective bores took some thought to not destroy the parent bore. The secret was to use 1/8" welding rod and literally weld around the inner circumference of the bushings, and knock them out with an air chisel. Usually they would walk out easily ready for another to be drawn in with either a hollow bore hydraulic cylinder, or a large "C" frame press.
            Some of the crap I used to do to support a growing family.....
              The bushings at at the top of the arms on mine are starting to get worn. Luckily I don't use this machine to make money. It also needs steering clutches adjusted. I only use it a few hours a week in the summer.
                Couple times a year shoot the adjustments and pivots with a penatrant oil to ensure you can adjust them when the time comes.....
                  What thickness steel should I use on the bucket? 3/16, 1/4? Would I be able to heat it with a torch and get it to bend to the contour of the bucket?
                    I'd use the same as is there already. Cut the bad area out and butt weld a new section in, then hardface in the same pattern as what's already there. You may need to have a helper running a rosebud to warm the metal and tack it into place as edges meet. A stiff piece of cardboard makes for a great template to take to a steel vendor to roll a small section to the correct contour also.
                      Look up posts on here by Calweld, who does this kind of work commercially, among many other things, and has some excellent pics.. Hasn't posted recently, but may be still around.
                      Edit: Part 1 is here, but a Part 2 also:
                      http://www.hobartwelders.com/weldtal...avator+buckets
                        I am still around, just not as much, and not on a regular basis. I have already rebuilt more buckets this year than most people will see in their lives. Since I don't visit here so much anymore, if anybody wants me to look at a particular thread, please feel free to either email me or private message me through this website, with a link to the thread. I would be happy to help if I can.
                        Thanks for remembering me, Northwelder ,,,,
                        Joe
                        *** Disclaimer ***
                          Joe
                          Don't forget us, with your pics of some interesting jobs!
                            Joe
                            We wouldn't forget you that easily!
                            Feel free to drop in on weekend nights.
                            Maybe we can scare off those pesky Rusky spammers.
                            sigpicViceGrip
                              I love my trade, but once in a while, I get weary of the same building
                              with the same paint on the walls, and the same excuses every day
                              by the same bunch of bosos who should have found a different way
                              to bring home the bacon.
                              It's then that I love to open a Calweld thread,
                              or a Spook II thread, and dream of greener grass.
                              Or at least different grass. Joe's work when finished
                              has that >There's nothing more to be said< look to it!
                              Phil
                              sigpicViceGrip
