Bearing Replacement
  • Bearing Replacement
    Some more bearing replacements. Like so many times "Blue wrench" to the rescue.
    sigpic
    a whole month since your last post?! whats going on with that?
    what is that thing ? some sort of ditch witch?
      Mike,
      That would be a stump grinder. We have come a long way since the ax and shovel, or even dynamite.
      sigpic
        Dynamite would be more fun........
        I suspect that the axle bearings in the cutter head live in a less than hospitable enviroment and receive no maintenance.
        www.flipmeisters.com
        Harris OA
        sigpic
          Is there room and fund$ for an "Upgrade" on the bearings?
          I have always wondered if those timing-belt hubs
          could be Ion-Nitrited..........to cut down on abrasive wear.
          The belts hold (become "charged") with grit and debriss
          and sand away the hubs.
          vg
          sigpicViceGrip
            Originally posted by urch55 View Post
            Mike,
            I saw a stump-puller when I was just a lad.
            Rated at 8 tons of pulling force!!
            A kind of chain-hoist under a Schwartzneger tripod.
            vg
            sigpicViceGrip
              vg
              Reminds me of last winter. My blower was frozen to the ground and D.A. me, backed the tractor up, hooked up the 3 point and the PTO and lifted the tongs. I promptly bent the sub frame on the blower... I didn't move. Never underestimate the power of hydraulics.....
              This time of year I have to use a sledge hammer on my wood pile to keep the fire burning.......
              Harris OA
              sigpic
                Pulling stumps out with my tri axle dump truck is alot of fun. Unless a chain gives out, then it can get ugly quick!
                HH210
                HH125ez
                Airforce400
                  Chevy,
                  Chain or Mini Wheeler ? I think the chain is the weakest link.
                  Even tho a strap or wire rope can be dangerous if it snaps under a load, I think they take a bit more abuse before a failure takes place.
                  I have seen many pickups with a dented tail gate with a chain impression in it. Some even cover the chain, cable or strap with a sizable piece of carpet. But I must say I never have.
                  What city do you call home in the greater Tampa Bay area.??
                  sigpic
                    Chevy,
                    Urch, I agree that the chain is the weaker link between the two. I actually keep a very thick wire rope used by cranes for lifting under my dump body. While loaded I have pull started other loaded mini wheelers, Pulled out a semi loaded with a milling machine that got stuck in the mud. My point being that yes they do take some abuse. I live in Dover which is in between Valrico, Seffner, and Plant City. Gulfport is a beutiful area, I guess its about a hour from Dover. Are you from this area originally?
                    HH210
                    HH125ez
                    Airforce400
                      Urch, Are you from this area originally?
                      Yes Chevy, Lived here in Pinellas county all my life. Born in St. Pete. (Cracker).
                      A few of my customers lease to Jason, which I understand has a large fleet themselves.
                      sigpic
                        Urch, Im leased on with World Haulers which is actually owned by Jasons Cousin. Many say its Jasons co. also and his cousin is a cover up. It doesnt matter, the important thing is that it feeds my family. I was born and raised in Dade County (Miami) and moved to the Tampa area in 1998. Love it over here and except for my family I dont even miss Miami. Anyway GOD BLESS my brother and well talk later cracker. Santiago
                        (the cracker part was a joke)
                        HH210
                        HH125ez
                        Airforce400
