Fencing wire
  • Fencing wire
    With a new roll of 100ft. horse-wire fabric to be stapled to RR ties,do you start with the roll wire outward or inward to be stapled to the posts?
    fencing wire
    Roll it outward, whether you are putting it on the inside or the outside of the ties. Otherwise you will drive yourself crazy unrolling and stretching the wire.
    You'll need to make a woven fence strecher out of 2 pieces of 2x4 that sandwich the end of the wire so you can pull on it with your come along.
      Easy way to unroll wire
      star,
      Check out link below. This thing makes it very easy. I built a similar one that I have used on woven wire as well as barbed wire works great.
      http://harveylacey.com/id34.htm
      Larry
      Try not to spend $10.00 worth time on $.10 job
