hello, we will have to make the metal frame of a small gib revolving crane, to be set up on a small truck bed, I think height 160 cm, jib arm length 150 cm rotation 200 degrees payload 200 kg 300 kg maximum. to bolt to the vehicle body. should be used to lift small equipment modest loads, we will have to fix it well with sturdy plates to avoid deformation of the frame and the body any useful suggestions? thank you
small jib crane swivel crane tip for pickup truck
thank you for your interest, I also thought I would fix the upright well with a sturdy plate.
gantry crane hoist built with your precious suggestions, box-shaped columns 100x 100 mm and H-beam ipe 180 capacity about 2500kg, if I can I attach other photos of projects realized with your precious suggestions.
- Likes 1
I fabricated a crane that mounts in my hitch insert, There are some good videos on Youtube on how to do this. Very easy to do and works well for my purposes. Quick assembly and disassembly. With a little imagination one could construct it in a way so as to be able to leave installed while driving.
Last edited by Hunter55; 01-20-2022, 06:06 PM. Reason: Just a quickie for now. The Small piece at the botton is a leg that is for ground support.
- Likes 1
