Well, here I go again! Recycling as I go! Its a Harley Brake disc to which is welded a Truck axle, supporting the 'lower half' of an oxygen cylinder (the axle runs all the way to the top "balancing" the cylinder on it) topped by a Bowling ball. The axle is topped with a truck lug nut, with the rounded end up, so the cylinder can swing. A 7/16" bolt is screwed into that lug nut, passes through a hole drilled in the center of the cylinder, and it topped with a couple nuts that slip firmly into the thumb hole of the Bowling Ball, which is suspended about 1/3" above the gong (so it won't mute the tone...same reason for the "swing" in the cylinder. The striker is a resin Croquet Balll mounted on a Croquet Mallet handle (25 " overall). The gong/ball is 35" tall.
It has a mellow tone, and a long after-tone, so would be well suited for Meditation Hut or Room....or as a "Door Bell"..or???
