1 inch plate welding table
  • 1 inch plate welding table
    Hello. Putting together a new welding table coming along pretty well, I was wondering if anyone had any input..should I put cross bracing on the underside of the table top. Being one inch plate I don' think it will need it but I like over building things just to be sure. Any input is appreciated.
    The welding table at work is 1" thick. They never put any cross members under it, and over time it developed some bowing. A new frame was made that has some cross members on it, that the plate is bolted down to. The plate is flatter now, but not as good as it was originally.
      Just flip it over once a year and you won't have any issues.
