Anyone ever build a safe?
  • Anyone ever build a safe?
    I have a new project in mind (like always) but this one is a serious step toward security. I am moving pretty soon from an apartment to a large house with my brothers and unlike an apartment, you can't just have a safe and bolt it to the ground unless you want to pay carpet repair fees So since i will have the space to work, Ive decided that i want to build one. It will house almost all of my valuables like my ar, cash, birth cert. Im planning on making it large, 4 feet high by 2 feet wide by 2 feet deep. The body will be 1/4 inch and the door will be 1/2 inch plate. I have some 3/4 drill rod I can use for the bolts. The inner will most likely be a drywall glued to the sides for fireproofing. I have already sourced the combination lock and dial. All of this material will still be by far cheaper than a real one at over $2000. my question is has anyone ever built one or is in the business of making them? any tips or suggestions on making it more burglar resistant?
    You can follow more of my work at www.siralloy.com
    Thats a heavy safe make sure the floor is up to the weight. I built them for 10 years. I lost my key and it took me 7 hours to get into mine and i knew how it was made...Bob
    Metal Master Fab
    Salem, Ohio
    http://www.ceilingtrains.com/
      Your design sounds good. I've built some gun safes for myself and my brother. The weakness is that they (and your's) can be cut with a torch or a cutoff disk on a grinder. My strategy is to prevent the punk burglar that comes unprepared. Someone that knows what he's doing can beat just about any safe. Your's should work good for you.
      Jim
      Miller MM 210
      Miller Dialarc 250P
      Airco 225 engine driven
      Victor O/A
        I wouldn't worry about keeping an AR in a safe. They are a dime a dozen.
