Hi all. This is a different kinda project. I want to be able to put a sheet of steel over the top of my gas barbeque grates for "grill cooking". The grate surface is 18"x24". There are several issues. One, I want to put a 1/2" tall edge all around to trap any grease. Two, I need to put a drain in it some where to drain off the grease. Three, how do I weld the edge (and get a good seal) all around without really warping it to death? I was thinking of using 1/4" plate for the top, how does that sound? Does anyone know if fabrication shops can bend 1/4" steel on all 4 sides? You guys are good so any thoughts out there? Uncrichie.
Grill Top For An Outdoor Barbeque
Two opposite sides can be formed easily enough, just hit it with the press brake. If the shop has what are called "sectional dies", they can also do the other two sides. Sectional dies come in various sizes, just add and subtract to get the inside width you need.
Most likely, forming 1/4" plate, the lip will be 1" or slightly more, to be able to use the correct bottom die.Last edited by calweld; 10-25-2008, 10:43 AM.*** Disclaimer ***
Thanks Calweld, that sounds promising. I can always grind the edge down to my desired height. That would only require corner welding, sweet! I have to figure in the placement of the drain, possibly through the front edge to a soup can. Keep it comin fellas. Uncrichie.
1/4" sounds awefully thick. Won't that take a long time to heat up and be kinda heavy. I just used some 12 ga sheet on a flat bed trailer I was working on and that seemed to be pretty solid. It would be easier to form as well since you wouldn't need as large a press to bend it. Just my 2 cents.
Or you just buy a ready-made cast iron griddle that's designed for exactly that, and be done.Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Hobart HH 125EZ
Originally posted by Zrexxer View PostOr you just buy a ready-made cast iron griddle that's designed for exactly that, and be done.*** Disclaimer ***
I've got a plate on 1/2 of my gas grill for toasting buns, grilling veggies, etc. Mine is 1/4" and does take some time to heat. As far as the grease goes, I drilled a series of 1/4" holes in mine about 3" apart. I can post a pic of it if necessary.Jim
Miller MM 210
Miller Dialarc 250P
Airco 225 engine driven
Victor O/A
Originally posted by bandsawguy View Post1/4" sounds awefully thick. Won't that take a long time to heat up and be kinda heavy. I just used some 12 ga sheet on a flat bed trailer I was working on and that seemed to be pretty solid. It would be easier to form as well since you wouldn't need as large a press to bend it. Just my 2 cents.*** Disclaimer ***
Uncritchie, consider having it slightly cross-broke first,,,, that is, a slight bump from corner to corner, an "X". This will raise the center a little, then drill a small hole in each corner, to drain the fat. It's a BBQ, don't matter if a little fat drips into the fire .....*** Disclaimer ***
Originally posted by calweld View PostActually, a griddle needs to have a certain amount of mass, so when you throw cold food on it, it doesn't suddenly loose heat, and will still cook evenly.
If you look at restaurant supply catalog better griddles will have thicker cooking surface. Thicker is better. Trough in front is much better than holes but might not work with your bbq. Separate left/right heat controls are better.
I have smallest rectangular Weber gas bbq. Only sell griddle for larger model. I have cut down an aluminum griddle from Walmart camping section so it fits inside with lid down or I use cast iron griddle when not packing in small car. Must have side burner for pots.
