Need biker/welder advice
Thanks for the answer guys. I will drop taking this one.Thank you for listening to sound advice. Seriously.
Need biker/welder advice...
Thanks for the feedback...now I get potato,and yeah that sounds right.I tried those clamp ons before..don't seem to hold full body weight...or maybe they have newer models out now...but I do have an aftermarket bracket that bolts behind the tranny made for this..but the kicker an the foot peg compete for the same space..so now maybe I can fabricate a peg that will bolt to the inside of the bracket...I agree much better than welding on the frame. Thanks!
Originally posted by panran View PostI have a ridged frame and am thinking about welding a couple of tabs for rear pegs,and one thats been been broke(for inner primary). It has a generator,small battery 12v.,and a joe hunt magneto.The motor is still in the frame but half tore apart.....Will I damage any of the electrics while still in the frame?
You can get chrome clamp on pegs. Many brands ,many styles.
If you need to re position the pegs for a perfect fit you can easily move them. Very important.
That way you can always take them off, and the frame is not altered.
BTW....Potato bike =Harley Davidson sound like potato,potato ,potato. Work on it.Last edited by donald branscom; 05-18-2011, 04:39 PM.
It's a rigid frame by the way and no electronics to speak of. A mag isn't effected by welding. Sounds like a potato bike.....
Would take about 1/2 hour to take the motor out. What is the problem?
If you install you're ground clamp close to where the welding will be done(grind off any paint for a good grounding), with the battery disconnected or removed there is no reason for worry.
I have a ridged frame and am thinking about welding a couple of tabs for rear pegs,and one thats been been broke(for inner primary). It has a generator,small battery 12v.,and a joe hunt magneto.The motor is still in the frame but half tore apart.....Will I damage any of the electrics while still in the frame?Tags: None
