Need biker/welder advice...
  • Need biker/welder advice...
    I have a ridged frame and am thinking about welding a couple of tabs for rear pegs,and one thats been been broke(for inner primary). It has a generator,small battery 12v.,and a joe hunt magneto.The motor is still in the frame but half tore apart.....Will I damage any of the electrics while still in the frame?
    If you install you're ground clamp close to where the welding will be done(grind off any paint for a good grounding), with the battery disconnected or removed there is no reason for worry.
    sigpic
      Thanks!...urch55 sounds like excellent advice!
        Would take about 1/2 hour to take the motor out. What is the problem?
        Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
          It's a rigid frame by the way and no electronics to speak of. A mag isn't effected by welding. Sounds like a potato bike.....
          www.flipmeisters.com
          Harris OA
          sigpic
            Potato bike
              If it was my bike I would NOT weld on tabs for foot pegs.
              You can get chrome clamp on pegs. Many brands ,many styles.
              If you need to re position the pegs for a perfect fit you can easily move them. Very important.
              That way you can always take them off, and the frame is not altered.
              BTW....Potato bike =Harley Davidson sound like potato,potato ,potato. Work on it.
                Thanks for the feedback...now I get potato,and yeah that sounds right.I tried those clamp ons before..don't seem to hold full body weight...or maybe they have newer models out now...but I do have an aftermarket bracket that bolts behind the tranny made for this..but the kicker an the foot peg compete for the same space..so now maybe I can fabricate a peg that will bolt to the inside of the bracket...I agree much better than welding on the frame. Thanks!
                  Thanks for the answer guys. I will drop taking this one.Thank you for listening to sound advice. Seriously.
