It's been a while since I've posted up any repairs, of any kind. This one come up, I thought it was unique enough, and maybe somebody could get some ideas themselves.
Note, this isn't one of them tutti-fruity racing or recreational vehicles. This is a working machine, out of a sheep ranch in Nevada. Country is so rough, and so high, they bring water/food/provisions to the sheepherders, the high summer ground, by pack-mules
Just scroll back in time, 200 years
I simply took a couple pieces of 1/4 x 1 flats, pre-formed them to fit, tacked the center section, on the bottom, then heated/hammered/clamped going forwards and backwards. Ending points both front and back, are in relatively low stress areas, very little possibility a new crack will start there. Then went back, welded every important point, plus every few inches in between.
I didn't waste a whole lotta time welding cracks in the existing tubing, but on the crossmembers, I did. Looking at the beating and distortion, last thing I wanted to do was put more material under the crossmembers, that might allow it to be caught on a rock, and perhaps just rip it out.
First two pics, as it was before I started. Note the bottom right hand corner, this was a huge chunk of steel, done as a emergency repair. Cut it off, didn't even bother filling the holes, the new metal wrapped right around it, it isn't even an issue.
Second two pics, the job as done. Note the new skid plate on the front, had a half-round 7" radius, 10 gauge, a little welding and hammering, fit perfect. Hopefully able to ride over the rocks, while trying to head off the sheep herd or trying to catch up with the coyote.
