modify ATV into ATV truck?
  • modify ATV into ATV truck?
    The cold weather is here, time to start dreaming of projects for next summer. I can find decent used ATV's out here in the country for somewhere around $1000 - some with 4 wheel drive. I don't have one here to look at, so......
    Would it be possible to lengthen the frame on any old ATV, extending the wheelbase, and turn it into a single seat Gator truck type vehicle? I figure you would have to extend the driveshaft, brake cables, controls, frame, etc. Fabricating a bed would be easy.
    Any experience? Any thoughts?
    Anything is possible. Without seeing any particular model , my first impression is that making up a whole new frame might yield a nicer final product. Design it to use all the suspension and drive parts from the donor. This way, you get to select your own clearance and width, as well. Remember, the longer the wheelbase, the lower the effective clearance over obstacles, and the more difficult to turn in tight woods.
      Thanks, you make some good points. Yes, may as well modify the whole frame, copy and use what I can. What DOM tubing do you think would be needed?
      Ground clearance isn't a real concern, as I will be using on relatively flat land, established paths, mowed fields, etc. I figure I can change the sprocket ratios to get more power and less speed. I guess I will have to keep my eyes open and start checking them out
        Flat open fields?
        Trailer
        Ed Conley
        Screaming Broccoli, Inc
        MM252
        MM211
        TA185
        SO 2020 Bender
        Miller 125c Plasma
          i did that to a three wheeler one time it was a 250 cc unit. it served well for the time that i had it. since then i have gone to a tow behind off road atv trailer that is also a people hauler. it can haul up to four people comfortably and all the hunting gear that we need. it tracks in the same track and if the four wheeler can make it so can the trailer. it is about perfect. if mine can tackle the woods and river bottoms i put it through then you can traverse fields with no problem.
            This is my solution... cost me 750 and didn't have to touch a thing on the atv
              Your ATV came with a ball hitch?
              Ed Conley
              MM252
              MM211
              TA185
              SO 2020 Bender
              Miller 125c Plasma
                Actually it did, however i took the stock one off and welded up a 2" receiver so i could mount a multitude of thing on the back end of it.
                  Arctic cat's atv do come with a 2" reciever. I have used mine to move my boat and atv trailer in my back yard.
                    I had to make one for mine
                    Ed Conley
                    MM252
                    MM211
                    TA185
                    SO 2020 Bender
                    Miller 125c Plasma
                      Aww, come on guys. If I wanted SENSIBLE answers, I could have stayed "in-house" with my question!
                      This is all about tearin', rippin', bendin' and weldin'!
                      And (ah-hem), sometimes i just do this stuff for the learnin', too.....
                        i would just build a new frame and mount everthing needed on it
                        Hobart Hood
                        Lincoln 3200 HD
                        Harris Port-A-Torch
                        The REDNECK Inferno Forge
                        110lb. Anvil
                        A Few Hammers
                        lil` Clarke Bandsaw
                        Git-R-Done Thanks, Chris
                          this would be my best suggestion seeing how you want the experience. it would look more unified and not look like a hack job.
                            Yes, I think the new frame will be the route I will take. If I follow through on my plans, I will post details next summer.
                            Thanks for all your inputs and suggestions
                            BTW, Scott -- any surviving pictures of that modified three wheeler??
                              unfortunately not. it was built on a 250 yahmahama. it was hard to steer when loaded, but it would haul a ton or better not really, but i could load it more than i really wanted to carry.
