Finally - Welding Table
  • Finally - Welding Table
    Well after several false starts and road blocks I have a welding table...
    A while back I acquired a piece of 1/4 inch plate that measures 26X28 inches....A while after I got a set of casters from local tractor supply... Some time has gone by...
    A few days ago I went to local metal supplier and was going to price out some 1-1/2 X 1-1/2 inch tube and to my surprise $159 for a 20ft. length and I need 30ft. .... Dream of finishing table sort of when "poof"...
    Came home and rooted around in scrap pile and came up with 4 sets of angle iron bed rail two sets at 1-1/2 X 2 inch and two sets of 1-1/2 X 1-1/2 inch (knew I grabbed them out of neighbors "free" offering for some unknow reason at the time), Well the 1-1/2 X 2 inch ended up being cut and welded together to create a tube for legs and other lengths of bed rail uses to form frame to hold it all together....
    Lot of hours of measuring and cutting and welding now I have a sort of table.... Top has been drilled with 1/8 inch pilot holes on a 4x4 inch grid to be late drilled to 3/8 inch for setting up fixtures, jigs and whatnots vice was something found shoved back deep in some dark shelf..
    Bottom tray is a section of 1/4 cement board left over from some home repairs ... Table is not complete as it needs a bar to hang clamps from and a few odds & ends.... But it very workable as it is... Probably will add a few tweaks at later date....
    Click image for larger version  Name:	Weld-table.jpg Views:	0 Size:	47.3 KB ID:	714304
    As table goes its sort of a light weight, but its for small home shop and will fill my needs...
    Lightweight as in thin or in moves around. If the latter, add a couple of cinder blocks to the bottom shelf when you're using it.
    Blacksmith
    Stickmate LX AC/DC
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
      Light weight as to how it was envisioned because of thinner materials in construction of frame, but it weight its heavy enough to be stable for my purposes .... Probably weighs in between 80 and 100 pounds... And it does have locking casters on two of its legs...
        Looks good, beats the floor.
          Just as a side note and not directly related to this table but the rage is to use tube for all this stuff. Last structural tube I use was something found for a bracket, another piece a while back for a bumper but angle is so much easier and rarely miter either. I was at the yard the other day, tube is in real demand was almost 2x as much as channel which was about the cheapest and cheaper than flat bar. I forget what angle was, in the middle I think.
          I built 200+ benches for a job in the 90's, they spec tube for the legs but I really rarely use it. On the net it seems like a requirement.
            It's a nice lookin little table. One thing you might want o add is a small piece of tube set at an angle so you have a place to put your stinger when you need to set it down. Also, I would swap out that cement board for some expanded steel, that way any dust, dirt or grit won't collect.
              The expanded metal is good idea, but I dont have any and have you prices any lately?
                Originally posted by Sberry View Post
                ...the rage is to use tube for all this stuff...
                Agreed that angle is almost always better. I built one of my early tables with tubing and realized quickly that it eats up a lot of your clamping capacity when you need to clamp something to it.
