What gauge 2” box for trailer ramp project
  • What gauge 2” box for trailer ramp project
    I am building a bi-fold trailer ramp for a motorcycle trailer. Each section will be ~ 78 x 36... I am planning on using 2” box for the outside frame with 2” angle for interior support structure, similar to the one in the attached picture.
    so the question: what gauge box tube should I purchase for this project?
    I want it sturdy, but no need for overkill - it will never have more than one 800 pound bike on it at a time.
    I recommend 16 gauge if you are a skilled welder, if not then go with 14 gauge. 16 gauge will burn thru much quicker. If You are using a stick welder then go with 11 gauge.
      It will be either Flux core or MiG - building it outside so I will likely keep the machine as currently setup with Flux Core wire.
      i would say I am an intermediate welder - so 14 sounds good to me.
      thanks!
        That sounds like good advice. The 2" square 16-ga will do the job, but the 14-ga isn't much more expensive, will be stronger, and will be noticeably easier to weld.
          ​ I wanted to stop back by and say thanks for the advice - project is done but for paint...
          It is heavy, but with the spring assist hinges I used, it can still be put up and brought down by one man.
          This was absolutely the largest project I have taken on with my welder, but it was a lot of fun and came out just as I planned. We won’t have to monkey around with ramps to load and u load our big bikes anymore.
ID:	712351 Click image for larger version
ID:	712347 Click image for larger version
ID:	712348 Click image for larger version
ID:	712349 Click image for larger version
            Ummmm .... Care to explain this picture......
              Lol... I knew someone was going to ask about that, and you are going to love this! I am running flux core in my welder, i am not using solid core mig w/ gas for this job.
              That is a bottle of 100% CO2 that I use to refill my wife’s soda stream and that is where it lives for lack of a better place.
              when I posted that photo, I noticed the upside down bottle and thought: yeah, that is going to raise a few eyebrows in this crowed!
                You totally should have come up with a much better story that would really have us wondering how crazy you are.
                  It’s for the new inverted gas penetrating shielded flow arc welding... you haven’t heard of that? It’s all the craze in California! lol
                    That's mo better!
