I would like to know something about metal fabrication. The construction work of our broadcasting center is going on. We are planning to consult one metal fabricator in Toronto named Bayview Metals. We need to get custom made rack mounts, control panels, chassis etc. Is there any criteria to follow when constructing metal components for a broadcasting center like metal type, tolerance etc..
Custom made metal components for broadcasting center
Originally posted by ernest View PostI would like to know something about metal fabrication. The construction work of our broadcasting center is going on. We are planning to consult one metal fabricator in Toronto named Bayview Metals. We need to get custom made rack mounts, control panels, chassis etc. Is there any criteria to follow when constructing metal components for a broadcasting center like metal type, tolerance etc..
Not sure why you need a lot of fabrication most telecom and broadcast and sound studio equipment is designed to fit in standard racks or equipment bays....
IF you need custom fabrication, generally mild steel materials with appropriate sized material to support equipment would be sufficient with appropriate series of mounting hole with universal pattern so if some equipment need changed in future it will fit without a lot of modifications... Also provide extra mounting holes for proper grounding and power outlets for racks and bays ... Main criteria is does company you selected has experienced in the type of design you require...
Originally posted by Dale M. View PostNot sure why you need a lot of fabrication most telecom and broadcast and sound studio equipment is designed to fit in standard racks or equipment bays....
