Some Handrails
  • Some Handrails
    Built these in a new housing addition going in. These is another set identical in another part of the addition.
    NorthridgeFab.com
    Nice job. It looks as flat as it does here. Where are you?
    Jim
    Miller MM 210
    Miller Dialarc 250P
    Airco 225 engine driven
    Victor O/A
      Thanks. I'm in NW Oklahoma City, OK
      NorthridgeFab.com
        Nice job! Straight, true and clean.
        Blacksmith
        Stickmate LX AC/DC
        Big cheap (Chinese) Anvil
        Hand cranked coal forge
        Freon bottle propane forge
        HH 210 and bottle of C25
          Nice job, Bryan...did ya fab them in the field or in the shop?
            Thanks. I planned on building them in the shop, but ended up just doing on site.
            NorthridgeFab.com
              Good job Bryon...did you core for the post's
                Looks fantastic, which tricks/tools did you use to keep everything so square and straight?
                Miller Dynasty 200DX
                Hobart T225 Stick
                Hobart Handler 180
                Airco O/A Rig
                ESAB W-200 O/A torch
                  I cored all the holes.
                  Cut the uprights 4 inches longer than the over all height of the rail when finished.
                  Set the uprights with Rockite cement.
                  The side walk slops towards the drain so I did not have level ground. So I set my height at each end and ran a string-line to set the height on the rest of the posts.
                  Then used a Pro-Tools tubing notcher to notch all the uprights.
                  I notched all the mid-rails in the shop with the notcher on the drill press.
                  Tacked in my mid-rails then top-rails, then finished welding.
                  Then the sucky part, PAINTING! I hate painting.
                  NorthridgeFab.com
                    I can't add anything to that!! I bid a small railing job on a residence just before Christmas. It needed to match the house trim. The home owner said he still had some paint and would paint it. YES!!
                    Jim
                    Miller MM 210
                    Miller Dialarc 250P
                    Victor O/A
