Transmission Case Repair - G Force T-5
  • Transmission Case Repair - G Force T-5
    This video details a repair to an aluminum transmission case that had a miss-drilled bolt hole and a crack close to that bolt hole. Both were repaired by welding up the defect and re-machining.
    https://youtu.be/iNFgRkZf1MM
