Ratchet Wrench
  • Roger
    I've seen ratchets used on big valves that were located so hand wheel couldn't work.
  • Ed Heimbach
    Dave, double threads are just as they sound, there are two helical paths circumscribed around the bolt.
    This is a special thread used mostly on clamping operations, some milling machines and lathes use them because the nut only needs to be turned a little bit to get a large movement on the shaft or bolt that to which it is attached.
    I hope that you find this helpful, Ed.
    P.S.
    I like your solution, it is a good example of putting common sense to work and getting the job done.
  • Dave Haak
    Threads
    Ed Heimbach,
    I assume faster thread nut means a coarser thread.
    About the other............OK.............I'll bite (no one else did):
    What's a double thread?.........cringe.....cringe.........
    My common sense has been taken over by my desire to possibly learn something.
  • Ed Heimbach
    Dave, maybe a good spot for a faster thread nut, or possibly a double thread!
    Just a thought.
  • ChadRat
    that is sweet! good job!
  • Dave Haak
    started a topic Ratchet Wrench
    Ratchet Wrench
    Got something that needs a full-time wrench? Tired of "wrench on/wrench off/wrench on"? Even dedicated a wrench to something, with a place to hang it, but it didn't get hung back up! Here's an idea.
    P.S...........................anyone have a similar project and need the 3/4" end.
