Ratchet Wrench
  • Ratchet Wrench
    Got something that needs a full-time wrench? Tired of "wrench on/wrench off/wrench on"? Even dedicated a wrench to something, with a place to hang it, but it didn't get hung back up! Here's an idea.
    Dave
    P.S...........................anyone have a similar project and need the 3/4" end.
    that is sweet! good job!
    Art is dangerous!
    www.PiedmontIronworks.com
      Dave, maybe a good spot for a faster thread nut, or possibly a double thread!
      Just a thought.
      Edward Heimbach
        Threads
        Ed Heimbach,
        I assume faster thread nut means a coarser thread.
        About the other............OK.............I'll bite (no one else did):
        What's a double thread?.........cringe.....cringe.........
        My common sense has been taken over by my desire to possibly learn something.
        Dave
          Dave, double threads are just as they sound, there are two helical paths circumscribed around the bolt.
          This is a special thread used mostly on clamping operations, some milling machines and lathes use them because the nut only needs to be turned a little bit to get a large movement on the shaft or bolt that to which it is attached.
          I hope that you find this helpful, Ed.
          P.S.
          I like your solution, it is a good example of putting common sense to work and getting the job done.
          Edward Heimbach
            I've seen ratchets used on big valves that were located so hand wheel couldn't work.
