just trying to upload a pic
CPB...........DO A QUICK SEARCH ON HERE THERE ARE AT LEAST 3 DIFFERENT WAYS TO DO IT ACCORDING TO ALL THE EXPERTS HERE....................ROCK
[email protected]
Just a thought....Make sure that your picture file is 100kb or smaller. Otherwise it won't post nor will it tell you it won't post.
Another thing is that you won't see it when you preview your message. Try again because we all like to see pictures here....
Main, I use several programs that do it easily. If you have software that came with your camera, it usually can do it. Usually I go to "Image Size" or something similar. Change it a little at a time. For instance, if your picture is 6"x10", reduce it to 5.5". Usually the two are adjusted together automatically. If you change one dimension, the other changes automatically to keep the picture uniform. Then save it as a jpeg. If you have a chance to adjust the amount of compression the jpeg uses, increase the amount of compression to make the file smaller and then save it. Check the file size and repeat if necessary. If you need more information, email me and I will try to explain it better. Try to keep it as close to the 100kb limit as you can to retain the detail.
I hope this helps....There are different ways to do it and I'm sure that other members on the site have their favorite ways. I'm sure they will chime in to help you.
Pics
CPB & Main,
Under FILE/Properties: Check the resolution (pixels per inch) of your image. If you start out at 300 per inch and you want to reduce the file size, try 275, 250...just work your way down. Each time you change the resolution check the image size and the file size. I've been doing this with Windows Explorer. My OS is Wiindows 98. I've been shooting for a maximum dimension of 6" to 8". Somewhere in this range you get the "enlarge button" in the lower right hand corner of the image, after it's been posted. With the program I'm using, I have to make sure I "Save" after changes or things get unbalanced. I hope this helps. I'll bet just about everyone here has had most of these same problems.
One other thing: With what I described above, I quit taking lower resolution pics. It was a pain changing the camera's settings. Just shoot the higher resolution and make the changes with your PC.
DaveLast edited by Dave Haak; 01-13-2003, 09:50 PM."Some days you're the dog, some days you're the fire hydrant"
Rather than make the picture smaller, I "optimize" it with ACDSee's Real Optimizer program....what it does, is make your file size smaller, with out making your picture smaller, It will reduce the file size from over 100kb to around 55 0r 60kb. ACDSee 5.0 is the fastest photo manager on the planet, with lots of bells and whistles. I highly recommend it.
Check it out...
http://www.acdsystems.com/English/Pr...DSee/index.htm
ACDSee
CPB,
Yup. It works. What is it? There must be a story here? Did you use the ACDSee 5.0? Sometimes I have too much software. So many programs for managing images, but to do all that I'd like to do, I can't do it with just one!! I have ACDSee 3.1 but do not see the optimize feature, probably because it's not there.
Dave"Some days you're the dog, some days you're the fire hydrant"
Success!!!
Thanks Rocky D, and all you other guys too! I didn't use the same optimizer you sugested because unless I just didn't look close enough there seemed to be only a trial version. I really hate those trial version programs so I looked into this freeware website.
http://www.freewarehome.com/
Then I found http://meesoft.logicnet.dk/
Through that I downloaded the 'Image Analyzer'
Try it, its free.
CPBDynasty 200 DX
Millermatic 180
Bluestar 185 DX
Grinders and
not enough clamps
Re: ACDSee
Originally posted by Dave Haak
CPB,
Dave
No you can't draw with it or add text...I use Adobe Photoshop Elements for that.
