My welder cart before hooks, bells, whistles, sandblasting and painting......
My humble trike....
Will, I used Tig, Mig and stick on it! I made it to use two bottles, but I don't know if I ever will. I need to modify the T-handle a bit so there's no chance of hitting the machine. It won't hit now, but I'd be a bit more comfortable if it rested a little further away. I still need to put the pedal platform on it and some tubes for rods, some cable hooks,etc. I'll use it for a while to see where I want everything and then go from there.
Rocky, I have another cart with a Thunderbolt at the bottom and a MM175 on the top. I may eventually put the mig on top and permanently set the Thunderbolt on a wall mounted rack. Maybe make some room for a plasma cutter! But before I get the plasma cutter, Momma needs her kitchen remodeled. I think if I can convince her that I could do woodwork with it, I might get it sooner than expected!
The cart is pretty maneuverable and more stable than I thought it would be. I can stand on the front corner and it doesn't tip, so I guess that it's stable enough. I needed the maneuverability.
That stability kept me from starting quite a few times, but I finally said, " I have a torch, a grinder and a welding machine. If it doesn't work, I'll do it over." But it looks like it will turn out ok.
Rocky D - yep, I thought about that area myself. That is where I plan to put my pedal holder/platform and I am going to try to incorporate the gussets in the assembly. Believe me, that is definitely the weakest part. The frame is 1 1/2" x 3/16" square tubing and the rest is 1/4" plate and angle except for the thin plate that the bottle is sitting on. Also, you were right about the pneumatic tires. With this amount of weight, it's just getting to the stage where one can notice the drag. If this would have been a little heavier, the solid wheels would have been the way to go.
