Stainless Steel Sink Cut and Welded together for Marijuana Grower
  • Stainless Steel Sink Cut and Welded together for Marijuana Grower
    Here in Michigan we legalized Marijuana recently. My customer previously was growing Marijuana for medical use and now he is expanding his operation for recreational use. There is currently a lot of profit in growing Marijuana. Somehow they wound up with a ten foot restaurant quality 304 stainless sink that was too long to get down the stairs to the nursery, so I cut it in half and welded it back together once it was moved back to basement.
    1. Ten foot sink
Name:	1. Ten foot sink.jpg
    The first step was to fabricate an Aluminum back up bar to trap the Argon and to minimize oxidation (sugaring) on back side of the weld joint. The next three pictures show clamping pieces of Aluminum angle to the bottom surface at the rear of the sink and tack welding it together.
    2. Back up on rear of sink 1
Name:	2. Back up on rear of sink 1.jpg
    3. Back up on rear of sink 2
Name:	3. Back up on rear of sink 2.jpg
    4. Back up on rear of sink 3
Name:	4. Back up on rear of sink 3.jpg
    The next pictures show clamping pieces of Aluminum angle to the bottom surface at the front of the sink and tack welding it together. I turned a bar of aluminum to fit into the round edge of the sink.
    5. Back up on front of sink
Name:	5. Back up on front of sink.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Here is what the entire back up bar looks like.
    6. Entire back up bar
Name:	6. Entire back up bar.jpg
    Here are two close up pictures of the welds, because this is after all a welding forum.
    7. Weld on back up on rear of sink
Name:	7. Weld on back up on rear of sink.jpg
    8. Welds on back up bar on front of sink
Name:	8. Welds on back up bar on front of sink.jpg
    I used my Matabo 6" angle grinder with a super slicer plus abrasive cut off wheel to cut the sink in half.
    9. Sink Cut in half
Name:	9. Sink Cut in half.jpg
    Next we stuffed Aluminum foil in the cracks in an attempt to keep the Argon from leaking out.
    10. Stuffing Aluminum foil in cracks
Name:	10. Stuffing Aluminum foil in cracks.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      We supported both ends of the sink on their legs and we supported both sides of the middle of the sink with two service jacks. Here is a picture of the sink tack welded back together
      11. Sink tack welded together
Name:	11. Sink tack welded together.jpg
      Here is a close up picture of two of the tack welds.
      12. Close up of two tacks
Name:	12. Close up of two tacks.jpg
      My customer asked me to continuously weld the halves together, but asked me to leave the weld as it was without dressing.
      13. Close up of continuous weld
Name:	13. Close up of continuous weld.jpg
      Here is a picture of the sink back together.
      14. Sink welded back together
Name:	14. Sink welded back together.jpg
      -Don
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        That's, like, groovy, man....
