Porch Railing Repair
  • Porch Railing Repair
    The railing on my rear porch was installed 50 years ago.
    1. Porch railing
Name:	1. Porch railing.jpg
    When it was installed they used Aluminum flanges on the bottom that looked something like the following, except there was a screw clamping the tube. The Aluminum in contact with the steel set up a galvanic corrosion situation in the presence of the salt and water used to melt the ice on the porch, which rotted off the bottom end of the tubing posts and rotted the aluminum castings.
    2. Aluminum flange
Name:	2. Aluminum flange.jpg
    So about 30 years ago I cut off the damaged bottom of the 1-1/4" tubing posts and oxyacetylene welded on 1-1/4" x 1/8" wall square tubing extensions and stick welded the extensions to 3/16" x 3" x 3" base plates. I attached the new base plates to the concrete slab of the porch with red head type anchor bolts. Eleven years ago I noticed that one of the tubes had burst from water freezing inside the tube as shown below.
    3. Burst tube
Name:	3. Burst tube.jpg
    So I TIG welded a tube to replace the burst tube.
    4. Tube replaced.
Name:	4. Tube replaced.jpg
    I added drain holes to bottom of all of the posts. You can see one drain hole if you look carefully in at the following picture.
    5. Replaced tube welded
Name:	5. Replaced tube welded.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    The posts lasted 11 more years until this year. The following picture shows the same post as it looked on this past Friday.
    6. Corner Post
Name:	6. Corner Post.jpg
    The bottom of the tubular posts were rusted out from the inside. It wasn't too apparent from the outside because there was a thin shell of good metal on the outside. Once I tapped it with a picking hammer the rust all broke off the inside of the tube and fell out as shown below.
    7. Loose rust
Name:	7. Loose rust.jpg
    Below is what one post looked like after I vacuumed up the loose rust.
    8. Loose rust cleaned up
Name:	8. Loose rust cleaned up.jpg
    Next I cut off the damaged tubing on the bottom as shown below.
    9. Bad tube cut out
Name:	9. Bad tube cut out.jpg
    Below are some of the ends of the tube that I cut off.
    10. Pieces cut out
Name:	10. Pieces cut out.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Next I ground the base plate to clean bright metal in preparation for welding.
      11. Base plate cleaned up
Name:	11. Base plate cleaned up.jpg
      Below is a picture of the TIG welding setup that I used on Saturday.
      12. TIG welding rig
Name:	12. TIG welding rig.jpg
      I clamped a bar to the side of the tube to align the replacement stub tube to the bottom of the post.
      13. Clamped for TIG welding
Name:	13. Clamped for TIG welding.jpg
      Below is the replacement tube end TIG welded.
      14. One post TIG welded
Name:	14. One post TIG welded.jpg
      I decided to remove the railing on the side of the steps to gain better access to the posts on top of the porch. I wound up breaking off all of the studs. In hindsight I thought I should have heated the nuts to remove them. Instead I just welded new studs to the top of the broken off studs.
      15. Stud clamp
Name:	15. Stud clamp.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        16. All studs welded
Name:	16. All studs welded.jpg
        I chased the threads with a chasing die to make sure that the threads were all ok.
        17. Chasing stud threads
Name:	17. Chasing stud threads.jpg
        I re-installed the railing on the side of the steps and tightened down the repaired studs.
        18. Railing base mounted
Name:	18. Railing base mounted.jpg
        I put everything away for the night and re-setup on Sunday, but this time I decided to MIG weld everything. I used my free standing fly to keep the sun off. Our weather here in Michigan got up to 90° F each day, so it was brutal welding outside.
        19. Keeping out of the sun
Name:	19. Keeping out of the sun.jpg
        20. MIG welding setup
Name:	20. MIG welding setup.jpg
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          I MIG tack welded the first post.
          21. Tack welded
Name:	21. Tack welded.jpg
          Next I MIG welded it out.
          22. MIG welded out
Name:	22. MIG welded out.jpg
          Here is my 2nd weld.
          23. Two welded posts
Name:	23. Two welded posts.jpg
          Here it is all done and primed. ( I still have to drill the drain holes.)
          I used 3/16" thick tubing instead of 1/8" so hopefully it will outlast me.
          24. All done
Name:	24. All done.jpg
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Well done...
