Mounting I-beam and chainfall over lathe
  • Mounting I-beam and chainfall over lathe
    Back in May I welded together a super structure that attaches to the joists and sticks through the ceiling drywall to support an I-beam. Once I move the lathe, the I-beam will be directly over my lathe. The I-beam will support a chainfall that will be used to lift heavy chucks and tailstocks for the lathe. Below is a link to the project to weld and install the superstructure.
    https://weldtalk.hobartwelders.com/f...ry-above-lathe
    Now that the drywall has been installed, this project documents the process to install the I-beam on the superstructure.
    The first picture shows a SolidWorks picture of the support structure weldment.
    1. Isometric assembly
Name:	1. Isometric asm.JPG
    The next picture is an exploded view of the support structure weldment shown above.
    2. Exploded assembly
Name:	2. Exploded asm.jpg
    The following picture shows the cross beam with "hockey pucks" that will stick through the drywall to provide support for the I-beam.
    3. Exploded cross beam
Name:	3. Exploded cross beam.jpg
    This picture shows the drywall lifting rig that my friend Ray brought over to be used to lift the 4" x 12' pieces of drywall for the ceiling. If you look closely you can see the support structure weldments in the ceiling
    4. Lifting 4ft x12ft Drywall
Name:	4. Lifting 12 ft Drywall.jpg
    I inserted threaded rods that were sharpened to a point into the "hockey pucks" of the cross beam of the support structure weldment. The threaded rods were used to mark the back side of the drywall with the location to hole saw clearance holes in the drywall to clear the round boss of the "hockey pucks". As you can see in the following picture the holes in the drywall aligned perfectly with the boss of the "hockey pucks".
    5. Threaded Points to mark hole location
Name:	5. Threaded Points to mark hole location.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    My nephew Phil came over from Arizona for a visit and he helped me to set up the spacing of the chainfall.
    6. Setting spacers on chainfall
Name:	6. Setting spacers on chainfall.jpg
    The next picture shows using a manual fork lift to lift the I-beam and chain fall into position.
    7. Lifting I-beam into place
Name:	7. Lifting I-beam into place.jpg
    Next Phil tightened the 7/16" screws to attach the mounting plate of the I-beam to
    8. Tightening Bolts
Name:	8. Tightening Bolts.jpg
    The last step was trying out the chainfall. As you can see I will have to shorten the drive chains.
    9. Trying out the chainfall
Name:	9. Trying out the chainfall.jpg
    -Don
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      WOW! Pat your back and shake your hand. Well done.
        Thanks.
        -Don
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          The last step in the process was to install a stop on both ends of the rail to keep the trolley from riding off the end. You don’t want to just use a bolt head as a stop because the wheels of the trolley can ride up on it and still come off the rail. The best system is to stop against the carriage of the trolley. By code modern trolleys have carriages that are designed to limit the amount that the trolley can fall if the wheels fail or fall off. My stop contacts this fall limiting bracket.
          Here is a picture of me machining the stop bracket. I machined the top at a 5° angle to match the slope of the flange of the I-beam. I also cut a radius in the corner. This project also gave me an opportunity to demonstrate machining on the milling machine for my nephew Phil, who is just starting his Junior year in Mechanical Engineering.
          10. Machining stop
          Click image for larger version  Name:	10. Maching stop.jpg Views:	0 Size:	78.6 KB ID:	705391
          11. Stop machined
          Click image for larger version  Name:	11. Stop machined.jpg Views:	0 Size:	56.2 KB ID:	705392
          My nephew Phil installing the stop.
          12. Phil Installing stop
          Click image for larger version  Name:	12. Installing stop.jpg Views:	0 Size:	30.8 KB ID:	705393
          13. Stop installed end view
          Click image for larger version  Name:	image_39526.jpg Views:	4 Size:	39.7 KB ID:	705394
          In this view you can see the bracket that limits the amount that the trolley can fall if the wheel fails or falls off.
          14. Stop installed side view
          Click image for larger version  Name:	14. Stop installed side view.jpg Views:	0 Size:	38.2 KB ID:	705396
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
