Kees 48" Commercial Mower Deck Repair.
  • Kees 48" Commercial Mower Deck Repair.
    My friend Rich from work has owned a Kees commercial mower to mow his one acre lot for the past 15 years. He got the mower from the previous owner, who owned it for 10 years. The front wheels are supported by wheel weldments that attach to the mower deck. Over the years the mower deck has thinned out due to rust and the deck cracked where the wheel weldments attach to it. Below is a picture of a Kees commercial mower.
    1. Kees Commercial Mower
Name:	1. Kees Commercial Mower.jpg
    Below is a picture of the cracked right side of the mower deck. If you look carefully on the right side you can see the three slotted holes, where the wheel weldments attach.
    2. Cracked deck on right side
Name:	2. Cracked deck on right side.jpg
    To beef up this weak section I bent up some metal to weld to the inside of the deck
    I decided to leave the old sheet metal in place to give me the location for the wheel weldment mounting holes. The first step was to move the front face of the deck back into position and close up the crack. I used the bar clamp arrangement shown below.
    3. Using a bar clamp to close the crack
Name:	3. Using a bar clamp to close the crack.jpg
    Once crack was closed and the deck was back in position I welded up the corner of the chute to hold the deck in place.
    4. Welding up corner of chute
Name:	4. Welding up corner of chute.jpg
    5. Close up of chute weld
Name:	5. Close up of chute weld.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Next I welded up the back side of the corner of the chute support.
    6. Open crack on back corner of chute
Name:	6  Open crack on back corner of chute.jpg
    7. Crack MIG welded
Name:	7. Crack Mig welded.jpg
    The MIG weld followed the crack as it should, but it left a space between the weld and the previous fillet weld, which looked like I miss located the weld, so I went over it with a TIG weld to straighten out the fillet weld.
    8. Crack TIG Welded
Name:	8. Tig Welded.jpg
    The next step is to weld the previously bent up piece to the inside of the right corner of the mower deck. I have found it helpful to use a lot of clamps to pull the old metal against the new metal so there is no crack to fill with the weld.
    9. First piece clamped and welded
Name:	9. First piece clamped and welded.jpg
    10. Second piece Welded
Name:	10. Second piece Welded.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      I noticed that the two surfaces that support the right wheel weldment were at an acute angle, so that the weldment bracket didn't sit flat. To solve the problem I cut off the thin old metal from the area that supports the right wheel weldment and welded in a 2nd piece of metal on the outside that was bent to exactly 90°.
      To bend the 2nd piece, I used my 20 ton HF arbor press with the Swag finger brake kit and the Swag Flat top adjustable bottom V die. The adjustable bottom die allows you to control the radius when you air bend sheet metal with a sharp punch. The narrower the opening the tighter the radius.
      11. Bending sheet metal
Name:	11. Bending sheet metal.jpg
      12. Swag Finger Brake
Name:	12. Swag Finger Brake.jpg
      13. Swag Flat Top
Name:	13. Swag Flat Top.jpg
      I clamped the wheel weldment to the 2nd piece of sheet metal and then transfer punched the hole location. Then I predrilled the holes on my milling machine. I used a shaper gage to keep the 2nd piece from bending due to the drilling pressure.
      14. Drilling 2nd piece
Name:	14. Drilling 2nd piece.jpg
      Next I clamped the 2nd piece to the mower deck using screws through the previously drilled holes. The holes in the mower deck were slotted so I had no trouble with alignment.
      15. 2nd Piece clamped with screws
Name:	15. 2nd Piece clamped with screws.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        16. Close up of 2nd piece clamped to deck
Name:	16. Close up of 2nd piece clamped to deck.jpg
        With the wheel weldment still in place I welded the 2nd piece to the inner new sheet metal and the thin old outer skin. In essence I used weld to fill the gap between the 2nd piece and the inner piece so that the wheel weldment would sit flat on the surface.
        17 Welding of 2nd Piece from top
Name:	17 Welding of 2nd Piece from top.jpg
        18 Welding of 2nd Piece from front
Name:	18 Welding of 2nd Piece from front.jpg
        Next I welded a piece to the left side of the mower deck. In this case the slotted holes were in thicker metal so I cut out the very rusted piece on the outside of the front of the deck.
        19. Piece welded to inside of the left side
Name:	19. Piece welded to inside of the left side.jpg
        20. Cut out piece on the left side
Name:	20. Cut out piece on the left side.jpg
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          21. Close up of weld on cutout
          Click image for larger version  Name:	21. Close up of weld on cutout.jpg Views:	9 Size:	65.7 KB ID:	704614
          22. The piece that I cut out
          Click image for larger version  Name:	22. The piece that I cut out.jpg Views:	8 Size:	54.0 KB ID:	704615
          I noticed that the metal just above the left wheel weldment was cracked so I ground it out and welded it up. Most likely it got cracked due to additional stress because the right side wasn't supporting its load.
          23. Cracks above left wheel weldment support ground out
          24. Cracks above left wheel weldment support welded up
          Click image for larger version  Name:	24. Cracks above left wheel weldment support welded up.jpg Views:	8 Size:	69.4 KB ID:	704618
          The center section between the pieces that I welded on the left and right was also thin so I welded pieces to the inside. The rust was thick and in a continuous layer, but it had to be removed to weld to the outer skin. After trying a variety of different methods I found that the needle scaler worked best. I would have preferred to remove the thinner metal in the center section, but I didn't want to add more hours to the job.
          25. Needle scaler good for removing heavy rust
          Click image for larger version  Name:	25. Needle scaler good for removing heavy rust.jpg Views:	8 Size:	76.0 KB ID:	704619
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            26. Two pieces added to center
Name:	26. Two pieces added to center.jpg
            27. Close up of center welds
Name:	27. Close up of center welds.jpg
            Next I cut off and replaced the chute guide.
            28. Old chute guide
Name:	28. Old chute guide.jpg
            29. Welds on inside of chute guide
Name:	29. Welds on inside of chute guide.jpg
            30. Welds on outside of chute guide
Name:	30. Welds on outside of chute guide.jpg
            sigpic
            Miller Thunderbolt
            Lincoln LE 31 MP
            16" DuAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              The last step was painting it.
              31. Painting deck
Name:	31. Painting deck.jpg
              32. All painted.
Name:	32. All painted.jpg
              My friend Rich sharpened and balanced the blades and put it back together again. I wondered about the name "Kutter" on top of the pulley cover it must be the model of the mower. I painted over the "Kees" decal on the mower deck after I repaired it, so I know that it is a Kees commercial mower. Below is the 48" Kees commercial mower back together. The grass cutting height is back up to where it originally was because the deck no longer sags.
              33. Back together again
Name:	33. Back together again.jpg
              sigpic
              Miller Thunderbolt
              Lincoln LE 31 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Well done on the repair and really well done presenting it. I enjoyed the posting. Thanks.
