Supercharger Casting Repair
  • Supercharger Casting Repair
    An friend and associate just purchased a used supercharger for his 15 year old Mustang, which he keeps in the garage and drives for special occasions. The super charger itself was in good shape, but when the previous owners engine failed something must have hit the drain plug boss on the bottom casting of the supercharger and cracked it. The first three pictures show the dent in the casting and some of the cracks that were present.
    Click image for larger version  Name:	1. Cracked Casting 1.jpg Views:	1 Size:	110.0 KB ID:	702894
    Click image for larger version  Name:	2. Cracked Casting 2.jpg Views:	1 Size:	102.8 KB ID:	702895
    Click image for larger version  Name:	3. Cracked Casting 3.jpg Views:	1 Size:	92.9 KB ID:	702896
    New castings are no longer available from Ford, so he asked me to weld it up. The first question is what Aluminum alloy was the casting made of. The casting was very smooth and there were what I believe might be ejector pin locators, which would indicate that it was die cast. Usually the ejector pins are 1/8 or 1/4 inch, but these were larger so I wasn't sure.
    4. Ejector Pins ?
    Click image for larger version  Name:	4. Ejector Pins.jpg Views:	1 Size:	88.8 KB ID:	702897
    The most common alloy for die cast Aluminum is 380. To confirm the alloy my friend brought it to a metal scrap yard and had them shoot it with their X-ray gun. The concentration of the various elements matched the Aluminum 380 alloy, so I purchased one pound of 2319 welding wire, which is recommended for welding this alloy.
    I decided to machine off the existing boss because the crack around it would be difficult to grind out and the threads in the boss were stripped as shown below anyway. What was left of the threads were also filled with RTV.
    5. Stripped threads on drain plug boss
    Click image for larger version  Name:	5.  Stripped threads on drain plug boss.jpg Views:	1 Size:	102.6 KB ID:	702898
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Because drain plug boss was cracked on three sides and only supported on one side, I decided to cut it with a hole saw, because I was concerned that a more aggressive means (Such as a large end mill) might damage the casting if the tool caught and ripped off the boss.
    6. Setup to hole saw off the boss.
Name:	6. Setup to machine off the boss.jpg
    7. Hole sawing off the boss
Name:	7. hole sawing off the boss.jpg
    Now that most of the material was removed, I could use a boring bar to remove the rest of the material and open the hole up to a standard size.
    8. Boring the hole to size.
Name:	8. Boring the hole to size.jpg
    Next I made a replacement boss for the drain plug. My friend didn't want to add the threads at this time because it is primarily required for the PCV valve that he didn't want to add just yet.
    9. Turning and parting off the new boss
Name:	9. Turning and parting off the new boss.jpg
    10. Grinding a drain passage in the top of the drain boss
Name:	10. Grinding a drain passage in the top of the drain boss.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Next I went over the cracks with the TIG torch to bubble the impurities to the surface. It also showed up the crack as a black line.
      11. TIG heating the cracks to bubble up the impurities
Name:	11. TIG heating the cracks to bubble up the impurities.jpg
      Now that the cracks were visible I ground them out from the inside of the casting.
      12. Grinding out the cracks from the inside of the casting.
Name:	12. Grinding out the cracks from the inside of the casting.jpg
      To keep the casting from cracking we preheated it before welding to 250 degrees F.
      13. Preheating the casting
Name:	13. Preheating the casting.jpg
      Next I welded up the cracks from the insides. In some cases I had to grind out the weld and re-weld it because there was still too much porosity in the weld. below is a picture showing the welds on the inside of the casting. It was difficult to weld because the casting was hot and the walls got in the way of the torch and filler rod. Below are the welds on the inside of the casting.
      14. Welds on inside of casting
Name:	14. Welds on inside of casting.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Then I ground out the cracks from the outside of the casting and welded it up.
        15. Welding the outside of the casting
Name:	15. Welding the outside of the casting.jpg
        16. Welds on outside of casting
Name:	16. Welds on outside of casting.jpg
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
