X-Mark Mower Deck Repair
  • X-Mark Mower Deck Repair
    My customer broke off the right hand bracket that supported the mower deck. I believe that the problem was that at some point in the past 5 years he hit something hard. Figure 3 shows a force diagram which would explain the dent that I observed in the top of the mower deck. The first step was heating up the dent and pounding it out against a large piece of steel.
Name:	1. Mower deck bracket.jpg
Name:	2. Close up of broken bracket 2.jpg
Name:	3. Force diagram.jpg
Name:	4. Dented mower deck.jpg
Name:	5. Dent heated and pounded out.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    The 1/4" support bracket was broken off clean and also had a crack about halfway through. I grooved and welded up this crack first so that the bracket had a chance of sitting flat on the mower deck. Next I clamped the bracket straight and pulled in the bottom of the bracket flat on the mower deck. It looks like a lot of clamps, but I added them one by one until the bracket was exactly where I wanted it and straight. I welded up the spider cracks and then tack welded the bracket in place. Next I welded up the groove in the 1/4" plate of the broken bracket to the piece still attached to the mower deck.
Name:	6. Crack in bracket welded up.jpg
Name:	7. Clamped for tack welding.jpg
Name:	8. Spider cracks welded and tacked in place.jpg
Name:	9. Tacked straight and ready for welding .jpg
Name:	10. Groove welded up.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      I added an additional bottom plate for additional support and hopefully to help stop denting of the top of the mower deck. I added an additional weld to attach the bottom plate of the broken bracket to the sides of the mower deck for good measure. I decided to beef up the 1/4' plate that broke with a fish plate, which I set back from the edge of the original 1/4" plate by about 1/5". The last step was priming and painting it. My shop was 50 degrees F so I used my 1000 watt shop lights and my 800 degree heat gun to help the paint to set up before we reinstalled the deck on the tractor.
      -Don
Name:	11. Bottom plate added.jpg
Name:	12 Extra weld added.jpg
Name:	13. Fish Plate added.jpg
Name:	14. Primed and painted.jpg
Name:	15. Close up of welds.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        did you also remind him to look where he`s goin
