Sub-Frame Repair on a 2010 Ford Flex
  • Sub-Frame Repair on a 2010 Ford Flex
    This week's project was to repair the attachment point for the steering rack on the sub-frame of my friend's 2010 Ford Flex, which he plans on keeping a few more years. I was surprised that it rusted completely though in eight years. My friend does lives one mile out on a dirt road, so dirt and calcium chloride that they put on the road to keep down dust, probably contributed to it. The following picture shows the rusted through steering rack attachment point on the sub-frame.
    1. Rusted rack attachment point
Name:	1. Rusted rack attachment point.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    In the following picture you can see a schematic of our approach. We manufactured a steel cup, which will serve as the new attachment point for the rack on the sub-frame. The steel cup is bolted to the sub-frame. The steel cup is fillet welded on both sides to a plate, which is in turn welded to the sub-Frame.
    2. Schematic.
Name:	2. Schematic.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      We manufactured a steel cup in the lathe. Notice the 1-1/2" drill bit. A 7-1/2 HP lathe has little respect for steel.
      3. Making steel cap
Name:	3. Making steel cap.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        We made radial cuts in the plate and formed it to the shock tower. Next we bolted the steel cup to the sub frame. We held the plate in place and tack welded it to the steel cup. Finally we removed the plate/cup assembly and welded it out on both sides in a vise. Notice that it is still red hot in this picture.
        4. Welding steel cap to plate
Name:	4. Welding steel cap to plate.JPG
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          We re-assembled the cup/plate assembly to the sub-frame. Then we welded the assembly to the sub-frame. The last step was to weld up the radial saw cuts.
          5. Plate welded in place
Name:	5. Plate welded in place.jpg
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
