Injector Tip Modification
  • Injector Tip Modification
    These injector tips are used to squirt paint against a distributor inside a bell cup on a paint robot for painting cars.
    For prototype testing we required a longer injector tip.
    We wanted to test it right away.
    So I cut the end of one existing injector tip and the base off a second one and welded them together to make the longer tip that we required.
    The following pictures tell the story.
    1. Half of two injector tips
    2. Welding the halves together
    3. Opening up the center hole
    4. Close up of lathe chuck
    5. Longer tip done
Name:	1. Half of two injector tips.jpg
Name:	2. Welding the halves together.jpg
Name:	3. Opening up the center hole.jpg
Name:	4. Close up of lathe chuck.jpg
Name:	5. Longer tip done.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Don, soon you will be doing this (with some up-graded equipment)!
    (Note the anatomical details!).
    This is from this interesting article
    https://www.thefabricator.com/articl...ll-and-growing
      Cool lathe chuck... Never seen one like that before....
        The Chuck is a Jacobs rubber flex collet chuck. Unlike 5C collects they handle the entire range of diameters very much like an ER collet.
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Neat welding process.
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
