Husqvarna Tractor Deck Repair
  • Husqvarna Tractor Deck Repair
    I welded the right hand support bracket back on the mower deck of a lawn tractor. The owner had attempted to weld it without success and then drilled a bunch of holes so that he could add angle iron brackets. He positioned the bracket in the wrong place so the belt hit the black link, so he ground a notch in the black link. I TIG welded up all of the holes using an Aluminum backing plate and I MIG welded the support bracket back in place.
    1. Broken Bracket on Deck
    2. Broken Bracket
    3. Failed Weld and Drilled Holes
    4. Ground Black Link
    5. Welding the Deck
Name:	1. Broken Bracket on Deck.jpg
Name:	2. Broken Bracket.jpg
Name:	3. Failed Weld and Drilled Holes.jpg
Name:	4. Ground Black Link.jpg
Name:	5. Welding the Deck.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Here are the rest of the pictures.
    6. Notch TIG welded
    7. Bracket Welded
    8. Close up of weld
    9. Close up of painted Bracket
    10.Bracket Mounted
Name:	6. Notch TIG welded.jpg
Name:	7. Bracket Welded.jpg
Name:	8. Close up of weld.jpg
Name:	9. Close up of painted Bracket.jpg
Name:	10.Bracket Mounted.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Guess what I was doing today.... Same thing on my JD riding mower, deck repairs.... Only a few cracks and the bar that connect both sides of the skirt (at chute) broke off..... Put some bar stock into lip, a little weld.... Save $814 dollars according to JD new parts list.... Got to finish it tomorrow but all the pieces straighten or repair and everything tack welded....So its simply finish welds and reassemble ...
      A trick I found out too... Blade spindles are anywhere from $40 to $60 (depending on source) plus shipping.. But I can buy the bearings for $8 each... So rebuild spindle costs me $16... If I do all three, $48, instead of $120 to $180....
        Nice trick.
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          That's a lot easier than washing all the dirty, wet grass clippings off the mower before putting it away!
          Nicely done.
