Side Posts Welded to New Trailer
  • Side Posts Welded to New Trailer
    I am currently working on an addition to the back of my garage.
    My two car garage is full of construction material and stuff I moved away from the walls that I had to work on in the other rooms.
    This means that I have can’t get my customer Sam's landscape trailer in the garage to work on it.
    Under these conditions I would normally work on it outside in the driveway.
    Unfortunately the past week has been snowing every day with 30 MPH gusts.
    I do have a 10’ x 10’ free standing tent with sides that I can position over the trailer to cut out some wind, but there are limits to how much wind it can tolerate.
    I bailed out and did the welding in a friend’s shop.
    I cut out the cross braces from the old trailer to use as posts for the sides of the new trailer.
    The MIG machine that my friend had in his shop was an old giant Miller transformer machine.
    The two dials just went from one to ten, so it was more difficult to set the proper voltage and WFS.
    I had Sam watch the volt and amp meters on the machine while I was welding to set up the machine.
    I ran some test welds because all machines are different.
    I used a clamp block and diagonal bracing to hold the posts in position.
    1. Cross braces cut off old trailer
    2. Old Miller Welder
    3. Test coupon
    4. Clamp block
    5. Diagonal Brace
Name:	1. Cross braces cut off old trailer.jpg
Name:	2. Old Miller Welder.jpg
Name:	3. Test coupon.jpg
Name:	4. Clamp block.jpg
Name:	5. Diagonal Brace.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Sam also helped my with the weld prep.
    I welded the 3/16" posts to the top of the upper angle iron rail of the new trailer, which was also 3/16".
    6. Sam grinding
    7. Me welding
    8-10. Welds
Name:	6. Sam grinding.jpg
Name:	7. Me welding.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Here are a few more welds and the completed trailer.
      11-12. More welds
      13. Trailer done
Name:	13. Trailer done.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
