Trailer Trashed -- Shelf Transferred to New Trailer
  • Trailer Trashed -- Shelf Transferred to New Trailer
    My customer, Sam, was minding his own business driving down I-75 with his dump body pickup and landscape trailer, A motorist cut him off. Sam was able to stop, but the car behind him wasn't and plowed into the back of Sam's trailer hitting it on an angle. The impact bent rear ramp and the side rails and pretty much every part of the old trailer. It pushed the trailer sideways so the wheel was wedged against the curb and bent the axle.
    Sam decided to replace the trailer, but wanted to keep the front shelf that I had fabricated for him three years ago. The first five pictures show the damage to the old trailer.
    1. Shelf on Front of Old Trailer
    2. Side Rail Bent
    3. Axle Bent
    4. Right Side of Ramp Bent
    5. Left Side of Ramp Bent
    Click image for larger version  Name:	1. Shelf on Front of Old Trailer .jpg Views:	1 Size:	91.7 KB ID:	700394
    Click image for larger version  Name:	2. Side Rail Bent.jpg Views:	1 Size:	83.2 KB ID:	700395
    Click image for larger version  Name:	3. Axle Bent.jpg Views:	1 Size:	64.0 KB ID:	700396
    Click image for larger version  Name:	5. Left Side of Ramp Bent.jpg Views:	1 Size:	88.9 KB ID:	700398
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    This set of pictures shows transferring the front shelf from the old trailer to the new trailer and welding it out. A carbon arc gouger would be the best way to un-weld the shelf, but I don't have one. Instead I cut it off with an abrasive cut off wheel and a Sawzall to give me a nice clean cut to weld to, The top of the old trailer was far from planer. If you look carefully in the upper right hand picture you can see a 1/2" gap between the post and the upper rail of the trailer. It also shows some of the welds. I used my Lincoln LE 31 MP to TIG weld extensions to two of the legs, because I had better control of the heat with the TIG process on the small parts and I typically leave the LE 31 MP set up for TIG. I used the Lincoln 210 MP to MIG weld the shelf to the new trailer, because I leave this welder set up for MIG and the 3/16" metal would be a little too much for the smaller welder. I could have done it all with the 210 MP but I was too lazy to switch it over from MIG to TIG and back again.
    6. Shelf cut off of old trailer
    7. Shelf Positioned on New Trailer
    8. Gap under Upper Right Hand Leg
    9. Weld 1
    10. Weld 2
Name:	6. Shelf cut off of old trailer.jpg
Name:	7. Shelf Positioned on New Trailer.jpg
Name:	8. Gap under Upper Right Hand Leg.jpg
Name:	9. Weld 1.jpg
Name:	10. Weld 2.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      This set of pictures shows the rest of the welds and the shelf welded to the new trailer.
      11. Weld 3
      12. Weld 4
      13. Shelf Welded to New Trailer
Name:	11. Weld 3.jpg
Name:	12. Weld 4.jpg
Name:	13. Shelf Welded to New Trailer.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        And now you can start repairing many of the faults in the old trailer again! For instance, those fenders should be replaced with some you can stand on....
          You are so right!
          In addition to the fender support, the span between the tubing of the ramp is 17”.
          The wheels of the X-Mark zero turn tractor fall halfway between the bars so the expanded metal must take the load until it fails. On the last trailer I added an additional bar between the existing bars right where the wheels go after the expanded metal got torn up. I also want to add a step in front of the tire to make it easier for Sam to get into the trailer.
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
