Make-up and Exhaust for a High Efficiency Furnace
  • Make-up and Exhaust for a High Efficiency Furnace
    Last weekend's project is to connect the make-up and exhaust PVC lines to my high efficiency furnace for my garage addition. The first step was to bend a piece of Aluminum to wrap a piece of 3/4" plywood. The wrapped plywood was installed in the Vinyl siding to give me a good mounting surface for the exhaust bezel.
    1. Box brake bending Aluminum sheet
    2. Wrapped plywood
    3. Wrapped plywood installed in siding
Name:	1. Box brake bending Aluminum sheet.jpg
Name:	2. Wrapped Plywood.jpg
Name:	3. Wrapped plywood installed in siding.jpg
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    The next step was to fabricate a brace to support the PVC pipes. First I dipped the end of the Unistrut into a container of Hydrochloric acid (Muriatic acid from Home Depot). The acid does a nice job of removing the zinc so you don't generate fumes when you weld it. Next I welded the base to the Unistrut using a Lincoln 210 MP welder.
    4. Removing Zinc with acid
    5. Welding the base plate.
    6. Base plate welded
Name:	4. Removing Zinc with acid.jpg
Name:	5. Welding the base plate.jpg
Name:	6. Base plate welded.jpg
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      The next step was to install the PVC piping and the newly fabricated Unistrut support.
      7. Installing the PVC Pipe
      8. Installing the Unistrut Brace
      9. Close up of Unistrut Brace.
      10. Bottom of brace
      11. Top of brace
Name:	7. Installing the PVC Pipe.jpg
Name:	8. Installing the Unistrut Brace.jpg
Name:	9. Close up of Unistrut Brace..jpg
Name:	10. Bottom of brace.jpg
Name:	11. Top of brace.jpg
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Very professional, as usual, and not something that would be as well done by your average HVAC guy! Let us know how well that furnace works.
          God job! Excellent photo documentary, too!
