Lawn Tractor Linkage Repair
  • Lawn Tractor Linkage Repair
    The linkage that controls the height of the front of the mower deck on my friend’s church tractor, fell off. It got caught in the lawn and created a lever, which the tractor used to snap off the linkage at the necked down area of the shaft. My friend hunted around the lawn and found the long bent part of the linkage, but couldn’t find the short threaded end. I replaced the missing part with the shaft portion of a 7/16” bolt. The bolt was zinc plated so I had to soak it in Hydrochloric acid (Muriatic acid) to remove the zinc before welding.
    -Don
    Pictures:
    1. Orientation view
    2. Close up of Intact linkage
    3. Close up of weld
    4. Weld after dressing
    5. Entire Linkage - all done
    1. Orientation view 2. Close up of Intact linkage 3. Close up of weld
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    That is why one pays the extra dollars for a John Deere....
      This tractor was purchased in 2000.
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        I have a 2004 with close to 500 hours on it....
          Click image for larger version  Name:	image_38123.jpg Views:	1 Size:	64.8 KB ID:	699053 This tractor had a hard life. Volunteer kids from the church learn how to drive on it.
          Here are links to other repairs that I have made to it over the years:
          It is hard to see, but this is where the repaired linkage goes:
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
