Railroad rails
  • Railroad rails
    I have a machine that uses railroad tracks to move a tank of water under an oven. It's a quench furnace. without getting too technical, this wheel of the car passes over an area that has worn down, causing the car to hesitate when the wheel moves over this low spot in the track. The fix is to build up with weld the low spot in the track and grind it flush. Simple.
    The question is, what stick rod to use, or could I use my flux core E71-t11, and would there be a special procedure to follow. The track is high carbon steel.
    ROCKY D........ARCHING AND SPARKING.......HAVEING VISITED THRALL CAR WHERE THEY MAKE RAIL ROAD CARS AND TALKING TO THE ENGINEERS ON DIFFERENT SUBJECTS.......SEVERAL YEARS AGO THEY TOLD ME THERE WAS SOMETHING GOOFY ABOUT WELDING THESE RAILS. I KNOW THEY USE A SUBMERGED ARC TO WELD THE CONTINIOUS RAILS TOGETHER NOW A DAYS.......SO LET ME GIVE YOU A PHONE NUMBER TO CALL WHO CAN TELL YOU WHAT TO WELD THE TIES UP WITH IT IS 937-332-5102. THIS IS ALICE SHE CAN TRANSFER YOU TO THE WELD ENGINEER FAMILURE WITH THIS DENNY, IVAN, BUTCH, KRIS, OR BRUCE IS WHO I WOULD TRY AND TALK TO..........
    BE SAFE.....ROCK... [email protected]
      Rocky, if you don't get satisfaction from the pros on this, write me. I have some thoughts that might help.
      Respectfully,
      Mike Sherman
      Shermans Welding
