The new mig set up I just bought came with a very limited cart. Here it is. I will be modifiying this to a more use able cart.
Welding cart
HEHE, any way the cart looks great so far, cant wait to see when its done. Keep sending pics, and dont forget to chree for OSU!!! [/B][/QUOTE]
OSU
OSU
OSU
OSU
RAW RAW RAWOMS
HH175
Red Tomstone W/ HF for TIG
Smith O/A X 2
Harris O/A
BridgePort
MSC cut off BandSaw 6X12"
And more!
Shop Mechanic for Brinks Coin
Thanks guys...
Ouch....Penn sure whooped State today. (not a big surprise but...gosh what a slaughter!!!).
I made a little more progress today and here is the latest pic.
I should be able to play most of the day tomorrow so hopefully I will have it ready for the trays. Then finish it up next week sometime.
Re: how some of my first welds turned out
Originally posted by deere_x475guy
This is what my welds are looking like. I need to work on this some. Any suggestions are appreciated. I am using flux core .035 wire.
Try to make your pictures 640 x 480 and 'optimize' them. I take any picture over 102,400 pixels and just optimize them with ACDSee's optimizer program addin, which reduces the file size 50%.
Welcome to the frustration of posting pictures. This too gets better with practice.
Looking at the weld, I think a light just went on for me. Many of the bead pix posted by the masters have overlaid travel path drawings; often a slight back and forth across the seam with a pause on each side. Just got the picture that the motion makes sure you are getting good melting on both halves. With a stright run you can get melting on one side and cold lap on the other; can look OK but not strong.
welds
Guys thanks for the feed back on the welds and the pic's. I was just running a straight line rather than what I did with stick welding (weaving back and forth).
Rocky...so you say I should also be going a little faster...to get the weld to lay flatter? Ok...I will try that this afternoon...
Gotta love this internet....it's just so easy to get in touch with the people that can really help....THANKS all..
Re: welds
You are running a fluxcore wire, which should mean that you are pulling the weld bead. Pulling the weld bead makes the weld bead want to pile up and be narrow. So except for thin sheetmetal you should be using a side to side weave to help flatten out the weld bead. The side to side motion also helps create a more consistent depth of penetration across the width of the weld bead.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
Re: Thanks Dan
Thanks Dan, that helped to clear things up abit. I take it then when I start using the mig set up I just use a straight line. Or do I still weave?
I have most of the cart done and as soon as I finish eating I will optimize and size as Rock suggested and upload...
Cheers..
I would say weave...but do a search on 'weave' and you'll find some interesting stuff.
