Here is the new bench that I have been working on. I'm not sure that something like this is ever done, (I'm still thinking about a drop leaf.) I have it set up to move about the shop in wheelbarrow fashion. Two 12" cast iron wheels on one end. The frame is 1.5x1.5.1/8 tube, and the top is 1/8 sheet. I made it thin so that it would keep the weight down. I can easily grind the top off and replace it if need be. Bolted a six inch vise to one end, and put a for square receptacle and cord on the other end. The lower shelf holds my grinders and tools.
My New Bench
Finally, I added two fold away handles on the end without the wheels. The go in under the bench when not in use, that way you don't walk into them accidentally. They also make a great place to put your ground clamp.Arbo & Thor (The Junkyard Dog)
nice table
Nice table Arbo,
But I'd need more handle than you show to move it around, especially with that big vice on the handle end. You must be stronger than me...
Love the wheels... looks like wheels from an old loading dock float ???
johnMy "project truck" has turned into 'garage art' !!!
Arbo,
I like the work table, it looks very useful. One question tho: Was there a reason you put that heavy vise on the end you pick up? Not being critical, just wondered.
Here's a photo of the Land Rover truck you asked about in one of my posts. Not me in the seat, it's the former owner.
Later,
Mike Pado
The vise does add some weight, but you'd be surprised how easy it moves. I put the vise on that end because I wanted to keep it away from the electrical outlet on the other end. I use a portaband to do my cutting, and didn't want the metal filings falling all over the outlet when I cut in the vise.Arbo & Thor (The Junkyard Dog)
I'm using the Milwaukee deep cut. I can cut 4" square tube no problem with it. The only thing I don't like is the fact that it is very difficult to get a nice square cut with it. I can't complain though. I picked it up used for $50.00 and have about $25.oo worth of parts in it to rebuild it. The parts are readily available from any Milwaukee service agent. If you call them, they will fax you a parts breakdown on the machine. I have gotten great service.Arbo & Thor (The Junkyard Dog)
milwaukee saw
Arbo...
I've got the same saw and the same problem... I thought it was just me... bad saw cuts are just one of the many features of the Milwaukee saw, I guess... but that puppy will sure cut !!!
Arbo,
In the first pix, is that the $18 angle grinder from HF? I could not resist at that price. It may not last like the more expensive ones, but it sure works good for what I need. Who knows, as a hobbist, my interest might shift is a year or two to ... ?
Bob,
You're right. That's the Chicago Electric from HF. I only use it to run a flap disk most of the time. It gives a great finish look on my ornamental stuff. Every now and then I put a type 27 on it if I can't get at something with the seven inch Milwaukee.Arbo & Thor (The Junkyard Dog)
