I revised the 3 point trailer hitch I made for my tractor so I could skid out logs with it. I welded a 1/2" x 1-1/2" bar onto the hitch. I slotted the bar so that a choker chain would lock into the bar. This again was welded with my HH175 using flux-core wire. I know I have seen a lot on this forum about the 175 having a limit of 1/4" but I have been using mine on much heavier stock with no problems. I think the key is that I am preparing the joint properly and using a wire that is suitable for multi-passes. I think proper joint design should be stressed a little more and not just using a higher amperage welder.
Anyways I have been using it on some pretty heavy loads with no problems. Even caught the hitch of logs on a stump once with no problem. Actually stalled the tractor.
Here is a picture of what I did.
