Hello, I've recently been building a table from metal tubing from an arial I had lying around. I have a problem when welding the metal though. I burn right through the metal. It happens most of the time but not all. I am using a 50 amp stick wleder, with 1/16 sticks. I find myself having to just tack all around the tube. Is that going to be strong? What is stronger tacking over and over till I get all the way around or just laying a full bead? Also is there anyway to stop te burnthrough? Thanks
Welder Burns Through Metal
That tubing is light and good tight fitup would help. Tacking up a few spots will help heat sink. I would tack up some and maybe fill the gaps a bit, then chip the slag off and come back and run a bead over top. Most sticks for that machine will be whip and pause rod, 6011 or 6013. If you are just trying to burn them around there its going to burn thru.
2 things come to mind, 1-the "arial" tubing is galvinized and by the time you burn through the coating, you`v overheated the base material, 2- try a 3/32 rod to lower the amperage on the machine [fixed 50 amp machine?]it never hurts to look [unless they`r WELDING!]
When you say "tack," is the small weld laying on top just to hold it momentarily, or is it actually a small bead that got penetration? I'm going to assume the latter. In this case, with the small thickness of your stock, if you were to "tack" it in this way all the way around, filling in the gaps after it cools, I think you would have as strong a joint as you can expect in this type of material, and for your purposes. With the limited capabilities of your machine and materials, I would not hesitate to build your project in this manner.
off topic...but..........
ross932c,
I can't tell if your avatar is smiling?????
Dave
Thanks again to the person who originally posted this. I won't name names...but feel free to chime in."Some days you're the dog, some days you're the fire hydrant"
Originally posted by keyen
how can i identify galvanized steel?
