I heard that you should grind tungsten rods "with" , in the same direction as your grinder wheel is turning versus holding the rod perpendicular to the wheel - reasoning being that you want the grooves in the rod running in the same direction as the current and that very small grooves running the other way disrupts the flow of current resulting in a less stable arc. I want to get the best results but grinding rods "with" the wheel can be really tough on the knuckles! What are you folks doing?
John
John
