I need you guys to pick your brains and give me some tips on building a sliding/rolling gate. The opening is approx 24' and I plan on using either 1 1/4 or 1 1/2" square tubing and cattle panel. I've built alot of regular swing gates but this is my first slider. I'd like to see some pics, if ya gottem. Gate hgt is 4', thanks
Need ideas for sliding gate
OK, I fired up my new autocad system "Aaron 2.0" and whipped out the sketch on how to do a sliding gate without an overhead gantry.
2 rollers are mounted at the back of the gate, and run inside the fence horizonatls. 2 rollers are mounted on the fence, and run on the outside top & bottom of the gate.
The rollers are about 8" diameter, and are available at fence suppliers.
Sorry about the colors, the markers that came with the software are sort of dried up.
slide gates
Ken,
I work at a steel mill and all our access gates (when unattended) use card activated slide gates.. slide your access card thru the reader and it turns on the motor that runs the chain that connects to the gate..etc...
these gates are either double or single with readers on each side so if it's double only one side will open when actuated... and the gate opening is at least 15' wide...some wider... they use a rack made of pipe that mounts to the fence.. a set of rollers ( top and bottom) ride this tubing rack to keep the gate plumb and square.. the gate frame itself is twice as long as the opening so it is supported in the closed position... hard to explain... easy to understand with a picture... they work very well with some maintenance (greasing/cleaning) but you can imagine the number of times they open a day 24/7 and the environment in a steel mill.
I'll take my digital camera tomorrow and snap some pics of the gate and its rack... don't guess you plan to use the actuators and such... it's just a two way chain operated motor opener. I'll try to get them posted Friday.. I'm out of town for the weekend..
maybe you can get some ideas from the pics...hope so
JohnMy "project truck" has turned into 'garage art' !!!
I guess it's Aaron to the rescue again.....
I think this is what Franz is refering to:
Thanks for all the input mi compadres. The gate has been put on hold for just a little while so I can finish a couple of bbq pits by the first......and the deer blind. I knew I could count on y'all to supply years of expertise. And ya gotta just make time to cogitate and fish !!!!!KenCo " Uccahay "
