need to cut quite a few slots 1/4" wide and 2" long in 18 gauge sheet metal and of course I need some in the middle of the sheet. All I can think of is a nibbler. Anyone have any better ideas???
Saber saw with fine tooth Bosch blade...drill the 1'4" holes at each end (I'd use a Rotobroach instead of a drill). Being how the slots will only be 2" long, perhaps just a cut off wheel in a 4 1/2" grinder to "connect the dots". this would be a great job for a CNC plasma cutter,,,if you happen to have one covered up in the back of the shop.
A straightedge and a die grinder/zip cutter/small router with a 1/4" dia cutter (two flute end mill or a single cut carbide burr). If you need squared corners, one shot with the nibbler.
I'v done a ton of slots this way, and with a little care, it is fast and clean. Normal concerns, of course, with using and controlling the high seed cutting tools.
