Some more ?'s from a FNG
  • Some more ?'s from a FNG
    Well I have just finished up my welding class - I never thought it would be this fun to learn to weld - but it is!
    I have been practicing my tube coping techniques that I have learned from you guys and things are proceeding along nicely.
    Here is the big question - what techniques do you guys use to get nice right angle curves in your tubing projects. I have seen the pipe bender at HF and realize that it will squish the radius of the curve some - that is not a problem for my application - but I just wanted to see if you moss-backs (or would it be spatter-backs) have some wisdom to impart.
    Thanks for all your help - I find myself cyber-slacking and checking the forum several times a day!
    Shooting in the dark here, but
    The tubing benders for EMT (electrical metal tubing) are sized so the diameter in the bending tool matches the diameter of the tubing. Bends show almost no deformation. A similar techinque might work for larger diameters?
      Re: Some more ?'s from a FNG
      Hey Doc, I have used the bender from HB, I usaually make 2 bends to keep from kinking the tube(for tree stands) or you can get benders from Lowes, Home Depot etc. in the electrical section. You have to get the bender size specific. I have enclosed the one I have for 1/2 inch.
      ROCK
        Congrats on finishing the class...now you BEGIN to learn...
        Tubing and pipe are measured differently...tubes OD...Pipe ID. That said, it is possible to bend tubing in a pipe bender, but it is much better to use a tubing bender for tubing and a pipe bender for (you guessed it...) pipe.
        Much was said on the old forum, complete with web links to see them. ( or was it here...senior moment...)
        I forget who said what, but I think they'll chime in.
          Specs Round Tube Minimum Outside Diameter (OD): 1/2" (12.7 mm) Maximum Outside Diamter (OD): 2" (50.8 mm) Minimum Wall Thickness: Depends on Die (See Die Charts) Maximum Wall Thickness: 0.134" Pipe Minimum Size: NPS 1/4 (DN 8) Maximum Size: NPS 1-1/2 (DN 35) Note: Our benders are rated for bending mild steel Schedule 40 Pipe. For other materials or Schedules, contact for details. Square Tube Minimum Size: 1/2" (12.7 mm) Maximum Size: 1-1/2" (38.1 mm) Minimum Wall Thickness: 0.065" (1.7 mm) Maximum Wall Thickness: 0.125" (3.2 mm) Other Specifications Minimum Centerline Radius (CLR): Approx. 3 x OD (See Die Charts for details.) Maximum Centerline Radius (CLR): 7" (177.8 mm) Maximum Degree of Bend: 180 degrees, depending on the die Features Great for custom fabrication applications Bend up to 2", 0.134" tubing or NPS 1-1/2 pipe manually! 100% Designed, Machined, and Assembled in the USA! Designed for a lifetime of constant use Forms quality, repeatable bends (less than 10% distortion in most cases) Creates 180-degree bends in less than 2 minutes (requires appropriate die) Tooling changes in less than 30 seconds All parts are CNC-machined for accuracy Heavy-duty 5/8”-thick frame arms Full selection of over 300 dies Converts to hydraulic in minutes Includes 105 Heavy Duty Tube and Pipe Bender Extension Handle Degree Plate with Pointer Stand U-Strap Pin, Center-Axis Pin, Backing Block Pin, Large Swing Arm Pin, Ratchet Handle Pin, & Small Swing Arm Pin Tensioning Bolt Warranty Our 105 Heavy Duty Bender comes with a 1-year warranty against manufacturing defects. For full details on warranty and returns, see our full warranty policy. Resources Tube and Pipe Bending Basics What Am I Bending: The Differences Betweeen Tube, Pipe, and More Lead Time Lead times vary by product. Many orders can ship out within a few days, but to make sure we offer our highest quality, some items our made-to-order. We never want to lose your business over lead time, so contact us if you need something ASAP.
            if you're gonna bend TUBE:
            if you're gonna bend PIPE:
            then harbor freight has what you need.
            - jack
