pipe burner build instructions
  • pipe burner build instructions
    (pic#1 and 2) 1" untested pipe. U can use black pipe but it's thinner and does not stand up to the heat and will rust and flake. Thread and cap end.
    (pic#3 and 4) gas mixer is a 1" cap about $1.50. Drill (4) 1/4 inch holes on face of the cap and drill and tap the center for a 1/8 inch npt thread
    Purchase a high pressure regulator. Heres one from amazon
    http://www.amazon.com/gp/search/ref=...ET6CHU3M5KOGTP
    PRESSURE REGULATOR 360#189 ADJ. W/EXFLOW POLY 36" HIGH PRESSURE HOSE
    part #32832
    In Stock
    Last edited by boykjo; 02-17-2010, 12:00 PM. Reason: added pic. end of regulator hose and part #
    sigpic
    Miller trailblazer 301G
    Miller S22P12 feeder w/ss case
    K&K 300 amp 15' .035-.045 (Bernard)
    Miller HF-251D-1, Weldcraft AC torch pkg
    Hobart HH187
    Harris DLX STLWKR
    O/A & chemolene
    WARNING These stunts are performed either by professionals or under the supervision of professionals. I insist no one attempt, recreate, or re-enact any activities performed.
    (pic#5) With a sawsall Start your first cut 4 inches away from the gas mixer or however far down the pipe you want to start as long as its no less than 4 inches and cut every 1 1/2 inches as far as u can go. Stop the cut into the pipe when a 1/4 inch of the blade is at the top and continue to your next cut. as u can see i wasnt paying attension and had to weld shut the first two cuts.
    (pic#6,7 and 8) With the end cap and gas mixer installed on each end connect regulator and position the slots underneath. connect tank and light.
    This pipe burner cost me $85.00. I dropped my digital camera and broke the lens. Went to best buy and bought another one to finish the pics. It normally cost around $20
    good luck
    completed instructions
    sigpic
    Hobart HH187
    Harris DLX STLWKR
    O/A & chemolene
      U can T and U your pipe burners. heres one that is teed
      sigpic
      Hobart HH187
      Harris DLX STLWKR
      O/A & chemolene
        Thanks.....I'll have to try that with my copy of my father-in-laws Holand Grill..... mine will be a bit bigger.....
        Mike
        George W. Bush saving your butt whether you like it or not!
        Thomas Paine
        HH210 w S.G.
        Victor/Uniweld O/P
        Dewalt Chop Saw
          thanks for the instructions. i am familiar with black pipe, but what is "untested pipe" and where can it be purchased? thanks again.
          5 rules for happiness:
          3. live simply
          4. give more
          5. expect less
          Rigid chop saw
          Rigid 3" drill press
          4 X 6 horizontal band saw
          porter cable 1410 dry cut saw
          O/A setup
          TA 185
          MM 212
          Cutmaster 52
            Untested pipe is piping not rated for pressure. It is used in handrails, roll bars, frames ect. It has a seem inside the pipe where black pipe is smooth. Untested usually come in schedule 40. Your local metal supplier should carry it.
            sigpic
            Hobart HH187
            Harris DLX STLWKR
            O/A & chemolene
              great post!! thanks for posting the instructions. just one question. what did you use as the jet where the hose connects to the mixing cap?
              i will post pictures of my set up for a home made weed burner or cooking jet burner. we made them at work so we could preheat some metal before welding.
                The black pipe I got at HD has a seam. The only common steel tube/pipe that I'm familiar with is DOM. Then again, I'm not edjumakated...
                I built a burner for a foundry from 3/4" pipe from plans online, but I hadn't seen too many plans for a burner of this sort before. Thanks!
                Dave
                Square Wave TIG 200 - Woot!
                MM180
                SP125+
                  The jet comes with the regulator and hose as one assembly.
                  heres the link or try your local farm supply house.
                  link: http://www.amazon.com/gp/product/B00...GPTYGGEG34FJTZ
                  sigpic
                  Hobart HH187
                  Harris DLX STLWKR
                  O/A & chemolene
                    i don't have a sawsall, but no reason i couldn't make the cuts with a bandsaw, right?
                    3. live simply
                    4. give more
                    5. expect less
                    Rigid chop saw
                    O/A setup
                    TA 185
                    MM 212
                    Cutmaster 52
                      Boykjo,
                      That is great stuff! I've seen the fluorescent and LED lights that you put under the running boards of a vehicle, but never gas-powered ones.
                        No but it's a good reason to buy a sawsall
                        Ed Conley
                        Screaming Broccoli, Inc
                        MM252
                        MM211
                        TA185
                        SO 2020 Bender
                        Miller 125c Plasma
                          I havent used a ban saw to make the cuts. Band saw blades can run a few 1/1000th smaller than a sawzall blade. you could try it and if it doesnt work u can always go behind your cuts with a sawzall. Remember to start your cut 4 inched from the gas mixer....
                          sigpic
                          Hobart HH187
                          Harris DLX STLWKR
                          O/A & chemolene
                            is this "at least" 4 inches? that is, if i wanted to T it first, then start making the cuts, it would more than likely be more than 4 inches. so, would that situation be ok? thanks.
                            3. live simply
                            4. give more
                            5. expect less
                            Rigid chop saw
                            O/A setup
                            TA 185
                            MM 212
                            Cutmaster 52
                              maybe a stupid question but what keeps the fire from sucking inside the holes, going up the hose, and in the bottle, causing a large KABOOM.
                              -Ryan
                              PowerMig 215
                              Precision Tig 225
                              Old Buzz Box
                              Hypertherm 600
                              HH 125 EZ
                              MM 350P
                              TB 302 w/ 12RC
                              Originally posted by scab
