This first shot is how it started this morning. Yesterday I fabbed these parts.
My Brake project via Dan
This is a little fab trick. When centering two parts together as shown...a quick way to find the center is to measure the length...say 9 and 13/16" for example. Well, you know its close to 10 inches, so divide by 2 = 5". Measure 5" from first one end and put a mark, then the other end put a mark. Then you measure between the two marks and that's your center! No figuring, or fumbling for your calculator.
Rock D Nice job, What welder did you use? Also didn,t know you used anti splatter on your projects -Thought it was to spray the mig nozzel with it. Great project Dan hope to start mine very soon, Dump truck is about done then I'll start this project and post my progress.Harold
Craftsman Colormatic AC
Victor Journyman Setup
Syncrowave 180 SD
MM210 With Spoolgun
Dynasty 200 DX
Spectrum 625 Plasma Cutter
Miller HD Tape Measure
My machine is a Miller[ (what else?) CP 300 using .035" ER70S-6 wire, 50 - 50 mix AR - CO2 setup on 480v input power.Last edited by Rocky D; 10-04-2002, 06:59 AM.
