Does anyone on this board, manufacture Marine Fuel Tanks? My Aluminum tank has a rust/corrosion hole in it. I didn't know Aluminum would rust.
I think I would rather have a new tank made, than fix this one. I'd hate to fix it, only for some other spot to rust through. I had to tear the floor out of the boat to get this one out, and I want to go back with another Aluminum tank or maybe a plastic one.
If you make these tanks, please email me at [email protected]
My Brother-in-Law, who's doing the floor and fiberglass restoration, said there is a company in NC that will build the tank if I send them pictures and specifications.
I posted the following message on a boatowners board.
I guess there's no way to assure another spot wouldn't rust or corrode through, if the present tank was welded?
Thanks for your help.
Don
I'm trying to locate a replacement below deck fuel tank. I may have to have one made. Can you name some sources that you've used for pre-made fuel tanks, or fabrication companies you have used to make a tank? Metal or plastic? I've measured my tank, and will take pictures.
Specs: 25 gal, 27 inch wide, 31 inch long, 8 inch depth at center. U shape tank with 5 inch sides, 8 inch base, 10 inch from base to side.
Don
