Shlurp is a Green, environmentally friendly, machine made with over 90% recycled material. It also replaces the 19 bent pieces of sheet metal I've made to drain oil from different machines and garden tractors, none of witch I can find when I need them.
Shlurp is made from one of the millions of 20# propane tanks that are now homeless because some government NITWIT decided tanks needed OPD valves.
The wheels are from an old system for spraying basement waterproofing, and the handle is from a floor scrubber. The onboard vacuum pump came from a hospital dumpster.
A dip tube was installed to within 1/2" of the tank bottom, and a port was added to the side of the nipple that replaces the valve.
Vacuum sucks the oil from the machine crankcase, and when the 20# propane tank is full, the hose on the pump is moved to the pressure side to discharge the oil from the tank.
Before removing the original propane valve, I ran a vacuum pump on the tank for a few hours, and then ran some Co2 into the tank before removing the valve. Neighbors downwind might have thought there was a skunk in the neighborhood during the evacuation.
