another finished bucket for the 318
  • another finished bucket for the 318
    Well, I just finished a Handy Bucket for a 318. This one fits on the JD 100, 200 and 300 series with two spool valves and a front hitch for the snow/grader blade. The bucket is the same as the first one I build except 8 inches narrower. The challenge on this one was to construct a hook up point to the a frame for the lift. This is what I came up with.
    Have fun all
    Short Term Memory GONE!!
    Hobby Weldor/Machinist
    Photobucket Shop Pics
    rear view
      rear side view
        This one has the JD hitch hooked up and dump cylinder mounted
          Very nice work Bob!How thick is the steel for the actual bucket?
            Hi Arc thanks, the bucket material is 1/8". The top edge and bottom cutting edge is 5/16". I have stress areas that are reinforced with 1/4".
              Thanks Aaron...is was a lot of fun..
                BOB.............HAVE YOU DUG IN THE DIRT WITH THEM YET....... .... I'M TELLING YOU YOUR HAVEING WAY TO MUCH FUN.... SOMEONE IS GOING TO COME ALONG AND WANT YOU TO MAKE THESE ON A FULL TIME BASIS..................THEN WHAT ARE YOU GOING TO DO.......... .................HAVE SOME FUN.................ROCK........
                  Rock...yes actually I have. I thougth I posted them to this board but I just did a search and didn't see them. Will was kind enough to let me dig up his yard..but he made me fill the hole back up...LOL. It was just a little over 4 feet deep. I will try to post the pics again to this thread so you can see it.
                  I have a web site started to give info on these buckets but lots of other things to do has kept me from finsihing it. Hopefully by July I will have it up.
                    Bob,where do you buy your cylinders,and hoses from?Nice Job also!
                      I get them from Surplus Center Scott...and thanks.
                        Bob,
                        Looks great! Glad you posted that last pic with the cylinders on. I was having trouble seeing how it would mount on the quick-attach on my 318.
                        Also, that lift cylinder looks like the one on my snow blower. How high will it lift the bucket? And what's the stroke on the dump cylinder?
                        Later,
                        Mick Lane
                        micklane
                          Rock here is a shot of a full load with the bucket
                          and here is the hole filled back in and graded...
                            Originally posted by micklane
                            Bob,
                            Later,
                            Mick Lane
                            Mick, the lift on the 318 is much higher...then I got out of my X475 bucket. It's close to 20 inches. The stroke on the dump is 8 inches.
                            I think this might slide onto your snow blower A arm. I know it does for the plow blade A arm. And the lift cylider is the one that JD uses for the lift on that setup. If your snow blower is different I can make one to fit it. Or design a completely different unit to eliminate the original factory A arm.
                            Thanks...
                              Bob,
                              I'll look at that A arm on my blower. I doubt the Deere guys used something different from the one on the front blade unless there was a need. The blower's a lot heavier than the blade, so if the one from the blade is strong enough, the one on the blower will probably work, too -- even if it is different.
                              I really do like the way it looks. Really good, simple design.
                              Mick
                              micklane
