Picture of A grinder stand I made for my brother-in-law. Freebe Just used 1¼" steel tubing. The rim was $5.00 at the local junk yard. Note the electrical outlet I added. It proved to be handy.
Grinder Stand
THE OLD ONE..........HEY HOW TALL IS THAT.......IT LOOKS TALLER THAN THE OTHER ONE YOU PICTURED IS IT??????/........ROCK
[email protected]
[email protected]LERWELDS.COM
Originally posted by morpheus
is there any "weight" or anything inside the rim that keeps it from
tipping over or is the board and stand plate just bolted to the rim ?
thanks....
- jack
I have made several of these type stands over the years; mine are mostly telescoping and adjustable with roller tops to provide varying height support for long material that overextending the table saw, drill press, chopsaw etc. An old mechanic in NY showed me his. He had mounted tubless tires on them. Thats what I use now. They are more stable, don't require additional weight, and roll around easy on the concret floor, no noise and no marks.Harold
Craftsman Colormatic AC
Victor Journyman Setup
Syncrowave 180 SD
MM210 With Spoolgun
Dynasty 200 DX
Spectrum 625 Plasma Cutter
Miller HD Tape Measure
