This morns project
  • This morns project
    I have to run irrigation water under some driveways in fields.
    here are a couple of shots of the ends. They couple to the aluminum pipe and are strong enough to drive over without burying deep.
      the other end,,, one male and one female. The unit is 30 ft long in his case to make the length a direct replacement for Alum.
        Nice job how deep do you put hat in the ground?
          He drives over it.
            Yes, I have 4, 5, and 6 inch ones but that is a 4 inch and we use steel so we only need to bury it far enough so the top is flush with the ground,, just so traffic can cross. Most times they are seasonal so I can pull them up and move them as we change the field locations.
